Go Back   HeliFreak > R/C Helicopter Support > Compass Model Helicopters > Atom 7HV
Atom 7HV Compass Atom 7HV Model Helicopter Discussion
Old 05-26-2012, 07:31 PM   #1
Jamesppp
Default Spyder 12S 4000mah packs
Rob43 said he would like to lighten up a little and try these packs. I bought a 2, 12S pairs to fly in my new 7HV. I am almost finished building the heli. I need to add and program the Skookum 720 FBL controller.
Here is a pic of the 12S stick (not hardwired but both connectors come out the same end of the stick) compared 2 a couple of random 6S, 5000 packs.
They seem very compact and only wei9gh 1200g
Are you guys using velcro on your battery trays? are we supposed to use the foam stuff? The Compass straps are good for the tray if you cut them off??
Compass7HV,Sk720HeliJive120HV Pyro 700 52L allHV
Outrage 550: Scorpion 4020-1390,CC125A ESC,WR ESC
Logo 5003D Scorpion Sk720 4020-1100, Blade130X MCPX
TT E-620 SE x 2: Scorpion 4025-740 CCHV85 ,770/8900
Jamesppp is offline        Reply With Quote
Old 05-26-2012, 08:08 PM   #2
Rob43
That is one slick looking pack. I use velcro on the pack/tray with the Compass straps. It works well for me. I see what you mean about how much smaller they appear to be. The connections up front make for a clean hookup, too. I removed the foam primarily because I thought it was for shipping protection, but that glue they used for attaching it is unreal!
= R
b43 =
Team Compass Support
Rob43 is offline        Reply With Quote
Old 05-26-2012, 10:24 PM   #3
Jamesppp
Are you using the Compass straps with no buckle? I thought there were 4 rolled up but there are only 2. I need to cut them down since to cant wrap them around the edge of the battery tray. I have more trays coming
I wish I was ready to go. I would love to fly it in the morning but Im not going to make it. I dont want to rush or Ill frick something up
Old 05-27-2012, 05:59 AM   #4
Mixmaster Pilot
I tape my battery's to the battery tray (keep the foam) with a good amount of packing tape. They will not move in a crash, and I just buy more battery trays for the battery's.
Rob, I was confused by the original battery tray foam that came with the first batch as well, ended up removing it but that stuff was sticky! It was mental compared to the newer trays.
Compass Atom 7HV, Scorp HK3 4035 hand wound by Mauro - 6x7x1.32 YY 430KV, CGY750
Beam E4, 6S, looking for a new FBL unit, BX is getting removed!
Formerly owned - Blade mCP X V2 - Blade 400 FBL BeastX
Mixmaster Pilot is offline        Reply With Quote
Old 05-27-2012, 02:56 PM   #5
Rob43
Sure was!
Jimmy - I use the stock Compass straps - 2 on each pack - also cut down to fit. No buckle. I like those Scorpion straps but couldn't get the XL size when I was shopping at the time. I bought them for my 6HV since the packs are perched on the plate. However, they aren't long enough for enough overlap for confidence when I run my 40C 6S3000 Sky Lipo packs. The L size should be fine for the 7HV tray, as they are only wrapping one pack to the tray. On my 6HV, they are wrapping two packs side-by-side, so not quite long enough.
= R
b43 =
Old 05-28-2012, 08:39 AM   #6
Rob43
Default Ordered!
Yesterday! Tired or waiting. Gonna get 'em. (1) pack ordered.
= R
b43 =
Old 05-28-2012, 05:17 PM   #7
Jamesppp
I bought a series connector EC5 for them. I soldered a Deans to the ESC....all my junk is Deans...picked up a Deans to EC5 to connect to the series connector
For charging I bought a Parrallel ECG harness, a female Deans to EC5 and a parrallel balance tap harness
T will only be able to charge 1, 12S pack as 2/ 6S in parrallel
My Cellpro 10 S has 2 channels but can only handle a 5S pack on each channel. For 6S packs you have to plug an additional attached balance plu into the second channel
Ill probably only be able to charge at 9 or so amps
Out of all the other 6S packs I have I can only put together 1 other 12S combo from two alike packs bought bat the same time. 6S 5000
The charger was fine when 10S was the the biggest packs I needed and I always just bought pairs af seperate 5S
I feel a charger coming up in the future after I recover from the cash hemmorage of the 7HV build...Rough on a poor boy
