Old 05-27-2012, 01:54 PM   #1
Jamesppp
Default HV servo setup
Ive never had HV servos before.
I have a switch harness that used a 4cell ni-cd battery that I use to setup my servos so I dont have to use the flight pack.
Is it OK to power the HV servos with slightly >6V to set them up while programming the SK 720?
Jimmy
Compass7HV,Sk720HeliJive120HV Pyro 700 52L allHV
Outrage 550: Scorpion 4020-1390,CC125A ESC,WR ESC
Logo 5003D Scorpion Sk720 4020-1100, Blade130X MCPX
TT E-620 SE x 2: Scorpion 4025-740 200srx, nano qx JR Parkmites x 2
Jamesppp is offline        Reply With Quote
Old 05-27-2012, 02:02 PM   #2
georgi UK
=] the SK is good for 2S, your servo's are also, so yes, carry on setting up!
georgi UK is offline        Reply With Quote
Old 05-27-2012, 05:53 PM   #3
dpelletier
Jimmy,
Using less voltage for setting up is not a problem... I actually use 4.8volts some times because my YGE Progcard can't go HV.
Bit of a nuisance, because my low voltage alarm on my Aurora 9 Tx just beeps non-stop.
Futaba 14SG, Synergy E5, Furion 6, Beam E4(v1) FBL, CGY750, Skookum
dpelletier is offline        Reply With Quote
