Go Back   HeliFreak > R/C Helicopter Support > 700 Class Nitro Helicopters
700 Class Nitro Helicopters 700 Class Nitro Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 05-27-2012, 02:39 PM   #1
saeed09
Default Cant fix the drift issue on my fb :(
I did interaction on the table and at field but when i kick for 3d and give some hard moves, the swash start to choose the position where to lean. Slightly moving in sides but the confusing part is it changes the position from time to time during flyng.
Changed servo horns to metal and everything is secured tight. Am using 690 blades SWE paddels and Torq servos. No binding too!
Any ideas with what could be the problem?
Inputs are appriciated in advance.
Sent from my GT-N7000 using Tapatalk 2
Trex 700N, Velocity 50 FB, Velocity 90 FB, TORQ servos,Futaba servos,JR servos,Spartan ds760, Quark, Dx7se, AR8000.
saeed09 is offline        Reply With Quote
Old 05-27-2012, 04:37 PM   #2
saeed09
I just put my heli on the table and noticed that in normal mode the swash is neat leveled, when i hit idle up1 the whole swash tilts right a little bit and when i hit idle up 2 the swash gets on the level again. If i hit throttle hold the swash tilts right too.
In Auto Dual Rate page i set them all to be the same. I doubt if this is the reason becouse i tried to put them all to zero, it still behave the same.
I did my table interaction at normal mode...now i realise and i believe that was wrong.
Which mode should i use to set my interaction?
Am i doing something wrong here?
Old 05-27-2012, 04:49 PM   #3
saeed09
Sorry...this sounds crazy but i forgot that my trim at idle 1 was off. Silly me. Issue fixed.
Need to rest from fixing and flyng i think
