| Gasser Helicopters Gasser Specific Discussion |
As the title says; What spark plug and the gap are you running on Zenoah engines.
Peace Out, Bobby D. X-CELL " PRo Gas WHIPLASH " G290Rc. HC3-SX, 8-FGH, MKS. Maidened 8/24/12 Flights 64 To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
NGK CMR7H
Using with Its original gap.
Trex 700 Gasser FBL | HeliBug HB7-RC 17T | Silverline V-Bar| TRM VX270TT | SG | RJX Gas muffler | JR x9503 Trex 600 Gasser FBL | HeliBug HB6-RC7 20T | Brain | GV-1 | Stock Zenoah G290RC | RJX pipe | JR x9503 |
Same as above... Although I've not operated the engine yet. :-P
~ Josh Helicommand/ bavarianDEMON Support Team KDE Direct - Field Support |
Never changed the gap, also with its stock gap.
-=>Raja.
1005 Xcell Autorotation Queen, Hanson G26 3D Max, 3327 flights Spectra-g, Hanson 270 3D Max, 2191 flights Whiplash-g 88.9mph Speed Cup Record, Hanson 270 3D Max, 265 flights Jewel on-board Generators, Team Miniature Aircraft, Team Helicommand |
I've done a few searches and have never found what gap I should be running run so I stick with the stock gap also. I believe it's .022. Let me know if that's not correct.
Jeff |
#6 |
My engine came with a NGK CMR7H gapped at 0.65mm / .025" I have since tried the Champion RZ7C at the same gap.
Finally the NGK CR8HIX gaped at 0.78mm /030" This plug seems to perform better,Fast starts 2 plulls,and runs smoother than all the rest.
