Old 05-29-2012, 06:00 AM   #1
urka
Default head gasket os105
hello do you recommend to add a head gasket for a OS105HZ with 20% nitro? thank you for your help
urka is offline        Reply With Quote
Old 06-04-2012, 04:15 PM   #2
Mizark
I am only running the standard 0.2mm shim in mine running 15% Rotor Rage & its perfect.
I would possibly think about adding the extra 01.mm shim if running 20%. It will make tuning easier & the engine run smoother.
Mark Lilley
Team Edge Rotorblades
Team Byron Fuels Rotor Rage
Mizark is offline        Reply With Quote
