Go Back   HeliFreak > R/C Electronics Support > YGE
YGE YGE ESC Support and Discussion
Old 05-29-2012, 03:40 PM   #1
opps
Default Help with YGE 7s Progcard
I have no idea to connect YGE 7s with Procard because it's no any instruction over the internet for the 3pins connector from the ESC..
Anyone help ?
ID:	320522   Click image for larger version
Spektrum DX8 & DX10T
mCP X V2 1.5 YGE 7s hp05s 12500kv 8T 400mAh 30c
GAUI X2 VBAR 5.2Pro Kontroik MiniJazz 20A JR DS380G
GAUI X5 AR7200BX CC100Lite Servoking DS-695 x 4
opps is offline        Reply With Quote
Old 05-29-2012, 04:18 PM   #2
helidude71
I have no clue, but why not try it?
If you put the red wire on the middle pin I guess no harm can be done.
T-Rex 500 ESP FBL, Microbeast v3, Scorpion HK-3026-1600, CC ICE 75
TSH Gaui X5 FES, Mini VBar 5.3 Pro, S.Bus, DS610s, DS650, YGE 100LV
Futaba T7C
Phoenix R/C v4
helidude71 is offline        Reply With Quote
Old 05-29-2012, 05:38 PM   #3
dpelletier
3 pin connector of the ESC to the left 3 pin connector of the ProgCard.
Negative (black or brown) to the right most pin, probably the same on the ESC
ProgCard right 3 pin connector to the Throttle channel of the Receiver (Rx)
Dany
Synergy E5 in the works
Furion 6 Flybarless, Skookum 720
Beam E4(v1) FBL, Skookum 540
dpelletier is online now        Reply With Quote
Old 05-29-2012, 09:54 PM   #4
opps
I think i messed up i know the Progcard side but not YGE 7s because it's selling "Light Weight" and it's no any cable on it. The ESC coming without any instruction for the which soldering point is for the programming. Anyone know ?
Old 05-29-2012, 10:34 PM   #5
desertstalker
You program it with the throttle lead, as to order, just try both, power is in the middle so you wont hurt anything if you get it backwards (it just wont work).
-DX8
Old 05-30-2012, 05:34 AM   #6
opps
i can use the TX for program just wonder how can i program it with the Progcard because YGE 7s without any cable or plug come with....
Old 05-30-2012, 08:44 PM   #7
desertstalker
Take the same lead you use to plug it into the RX and plug into the prog-card...
-DX8
Old 05-31-2012, 11:28 AM   #8
opps
Thanks !!! I think i got your meaning and i just draft a diagram attached, is it like that ?
Old 05-31-2012, 12:00 PM   #9
dpelletier
That ought to do it.
Dany
Old 06-06-2012, 05:42 PM   #10
maarset
Let us know how this works on your MCPx. Very cool
Logo 500 VBAR GOV/YGE
MSH mini-p VBAR
mcpX V2
mikeaarset.zxq.net
maarset is online now        Reply With Quote
