Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > 120 SR
120 SR Blade (eFlite) 120 SR Helicopters Information and Help
Old 05-30-2012, 11:20 AM   #1
JayP
Default 120 sr receiver keeps switching off!
Hi there,
I hope someone has had this problem and can help me out, its very frustrating.
Basically it took a ton of tries to get the 120 sr bound to my new Dx6i.
But when it did finally work, i only ever managed to lift off the ground for a few seconds before the light on the receiver would switch off and the TX would have no effect on the heli!
So I would unplug the battery, plug it back in, it would pick up the transmitter again (solid light) and then REPEAT eg. few seconds later, receiver light goes off, no input
Sometimes it would stop working but the blades would still be spinning and i'd have to run around the room trying to catch it.
Any ideas? Very frustrating.
Thanks in advance,
Jay
JayP is offline        Reply With Quote
Old 05-30-2012, 01:50 PM   #2
JayP
and also, I just tried to rebind to see if that fixes anything...It won't bind. I've tried 20 time it just wont bind.
Something wrong with the receiver?
Old 05-30-2012, 02:40 PM   #3
markus45
How close is your tx to your heli when binding, should not be to close. Are batterys in Tx fully charged.
markus45 is offline        Reply With Quote
Old 05-30-2012, 02:46 PM   #4
JayP
Yeah I read that, i've been keeping it about 3 ft away while trying to bind. Also the tx batts are brand new. still no luck.
Thanks for the reply.
Jay
Old 05-30-2012, 02:51 PM   #5
Heli-cat
I've always been curious as to the rationale behind this...I've had my TX sitting right next to my heli plenty of times while binding and never had an issue...anybody know?
Heli-cat is offline        Reply With Quote
Old 05-30-2012, 03:15 PM   #6
JayP
oh and by the way, the 120 sr is also new, I got a BNF version.
So it seems like even though i cant rebind it, if i switch on the tx first and then plug the heli battery in, it connects. But like my original post, as i lift off, or even just move the right stick around it will suddenly just stop, receiver light off for a few seconds no response and then BAM, reconnects to tx automatically, over and over and over. ARG!
Old 05-30-2012, 04:17 PM   #7
jaybird111
could have loose connections at the red plugs ..either the heli female red connector or the male battery red connector . I find them to be to tight and have pulled loose some wires when trying to disconnect
JayBird
I love to Fly every day
(2) 120sr's ...One Max Axe cp 2.4 and a Trex 250
A Dx6i and a stock pile of parts
jaybird111 is offline        Reply With Quote
Old 05-30-2012, 05:18 PM   #8
JayP
Hmm, well from what I can tell the connections seem to be fine. Does anybody know who I should contact about being given faulty parts here in the UK?
Horizon has support but only in the US. maybe I should call the shop I got it from...
I dont have enough technical knowledge to know how to fix it if its an actual problem with the ESC/receiver board thing. so disappointing, havent even had a chance to use it yet, last time i tried to spin it up the tail motor seemed to have completely stopped working as well...and then it all died as usual.
Thanks for the replys
Old 05-30-2012, 05:20 PM   #9
Heli-cat
Definitely contact the retailer that sold it to you...sure is an odd problem, and you shouldn't have to be stuck with it.
Old 05-30-2012, 05:37 PM   #10
Pfloyd
Fresh batteries in the Tx?
MCX/MCX2/MSR/MSRX/MQX/C105B/S300/MCPX/S107G/S107C/S109G/S108/S026/S009G/S023G/S102G/S110G/GYROPTER/
AIRRECON/UDI-803/UDI-816A/SYMAX1/V959/JXD-355/052INTERCEPTOR/EYE1/S113G/UDI-U810/
DX7s
USAF RETIRED (1968-1988)
Pfloyd is offline        Reply With Quote
Old 05-30-2012, 06:48 PM   #11
JayP
Yup, fresh battery's.
Old 05-30-2012, 07:28 PM   #12
jaybird111
I thought I had a problem with the 5 in 1 board but what it turned out to be was the wire connections would cause the break in power . Mine would seem to be fine and power up , gyro start and have a steady light but with some flight it would lose power. Just after some careful testing on the ground I found that the wires would lose power if they were moved in a certain way.
Jiggle them some and move them around and see if the light stays on .
JayBird
Old 05-31-2012, 04:45 AM   #13
JayP
No luck, and I broke one of the ball joints off the swash while trying to take the 5-in-1 off fora better look. This is ridiculous...
Old 05-31-2012, 05:36 AM   #14
JayP
So...the store I got it from told me to call horizon hobby here in the uk, so I did that, and the guy there told me to send the 5-in-1 to them in the post with a covering letter, proof of purchase and return address, and they would take a look at it.
I've had this thing for 4 days without being able to even use it and now it looks like I'm going to be waiting a hell if a lot longer still so frustrated.
Old 05-31-2012, 04:37 PM   #15
JayP
Well this sound pretty much like my problem, could I go about fixing these wires myself? I haven't sent the board in yet
Old 05-31-2012, 07:49 PM   #16
jaybird111
What happened with mine is that the red connectors for attaching the battery were too tight . After a few flights and tugging on the red connectors/wires to unplug and hook up another battery there became loose connections in side the red connectors. On one bird I replaced and spliced a new connector to it. The other bird was not loose enough to warrant that and some tight wrapping of electrical tape to the wires and connector help prevent any more tugging on the wires. I also pulled loose wires on two batteries . My friend did a re-solder job on those . I have since sanded my battery leads a little on three sides to make for a looser fit .
JayBird
Old 05-31-2012, 11:09 PM   #17
Heli-cat
I learned my lesson the hard way, when removing the battery to ensure I have a solid grip on the connector coming off the board as well as taking care to keep a little slack in the wires when disconnecting. I also don't jam the connectors in tightly - just enough to make a solid connecion...haven't had any loose wiring issues since adopting this method
Old 06-01-2012, 06:07 AM   #18
JayP
Thanks for the reply's guys. Problem is it was like this straight out of the box, and the fact is I still can't get it to rebind. If I knew what I was doing and could put a new connection on to test then I probably would, but as it stands i guess im just going to have to send it in.
Unless i just buy a new 5-in-1 instead, i'll be upset if sending this off to horizon and waiting for them to send it/or a new one back is going to take ages.
Jay
Old 06-01-2012, 12:48 PM   #19
Pfloyd
Has the red antenna wire broken off the 5n1?
DX7s
Old 06-01-2012, 05:36 PM   #20
Skapr1
I know this is a long shot, but could the flight battery charger be defective and not properly charging the battery(s)?
Skapr1 is offline        Reply With Quote
