| KDE Direct Upgrades and Accessories KDE Direct Upgrades and Accessories Factory Support Forum |
What are the parts needed for this?
I beleive you need the kde head upgrade along with gaui blade grips feathering shaft and dampeners. I want to upgrade to this myself but will probably wait due to the expense of replacing something that is functioning okay so far and I need the money to convert my whiplash to an 800 running the kde motor on 14s.
#4 | |
I don't beleive so but am waiting for a reply back from KDE.
#6 |
#7 |
Gotta love the KDE support. I sent an e-mail early this afternoon to KDE to ask about the head system and received an e-mail approximately an hour ago in response from the owner of KDE. The gaui mainshaft is good to use but I forgot to add the feathering shaft sleeve and the align main grips you need are part no. HN7116.
#8 |
After talking with Mitch, you do run the stock Gaui X7 shaft and then the ALIGN components for the full setup:
Dampers: H70096, TREX 700DFC Head Damper Flybarless Grips: HN7116, TREX 700 Newly Main Rotor Holder Feathering Shaft: HN7025, TREX 700 Feathering Shaft Feathering Shaft Sleeves: HN7111, TREX 700 Feathering Shaft Sleeve Everything else is included in the kit and you're good to go.
-- KDE Direct, Inc. -- |
#9 |
are you able to get those grips mentioned without "align" on them ? i surell wouldnt want and x7 with align written on any part
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Team A-Main/ProTek Field Rep. |
#10 |
Not that I'm aware of, but I have seen cases where customers with some polishing compound have taken quick work of the laser-etch engraving.
