Old 05-30-2012, 06:15 PM   #1
draeh
Default Just purchased a 450 Pro V2 3GX... what receiver?
I've seen many people using the AR6115 along with the 3GX and its cheap enough that if I don't like it I won't feel to bad about the $40.
Anyone using the AR6115? Like it? Work satisfactory? If you had to do it again would you?
Any suggestions are greatly appreciated.
draeh is offline        Reply With Quote
Old 05-30-2012, 06:47 PM   #2
satgod
if you truely are not sure
get a 6 or 9 channel orange reciever and 1 orange sat. about 18.00 shipped from hk
enjoy and if you really like it you can go branded later
the orange receiver will probably do you fine for a 450 anyway
there are several guys here that fly on them
Trex 600EFL Pro V2 V-Bar ds610 ds650 cc pro bec Scorpion 130a HV KDE 600XF-530
450pro 1860kv(6s) cc50 (4 DS215MG) 10t pinion, Tarot DFC, Ikon
TBS Discovery (Quad), naza-gps, 900mhz fpv, gopro2, ET OSD pro, D/L UHF
X-8 Wing , D/L UHF Full fpv package
satgod is offline        Reply With Quote
Old 05-31-2012, 10:44 PM   #3
Crashtestheli
Ar6115e works perfect. Easy to install
Crashtestheli is offline        Reply With Quote
Old 06-01-2012, 05:31 AM   #4
mtuccio
What radio are you running?
If you have a DX6i then the AR6115e will work fine for this application (make sure you place your antennas correctly to avoid shadowing)
If you have a DX8 then just go out and pick up a DSMX Satellite receiver to use (you only need 1 for a 450 sized machine and the 3GX only works in DSM2 but the DSMX Sat will work fine)
Hope this helps....
mtuccio is offline        Reply With Quote
Old 06-01-2012, 09:14 AM   #5
draeh
Hope this helps....
I did purchase a DX8 (not here yet). Are you saying that all the servos connect directly to the 3GX? (the 450 kit isn't here yet either) And that a satellite receiver is all that is needed?
I must profess, all this new radio technology is new to me. The last time I flew a heli was 2000 on a Kyosho Concept 30 with a 72MHz PCM Airtronics radio.
All help and suggestions is greatly appreciated.
Old 06-01-2012, 10:13 AM   #6
mtuccio
If you bought a DX8 package (SPM8800) that comes with a Rx then you actually don't need to purchase anything. The Rx in the DX8 package is the AR8000 which already has a DSMX Satellite included. The 3GX has the ability to attach two Satellite receivers right to the side of it so you do not ned to run a dedicated receiver by using this setup. You will attach the Servo, ESC, and Satellite wires directly to the 3GX and this becomes your complete FBL system. It makes for a very clean and simple installation that is easy to wire up on smaller helis...
Hope this helps...
Old 06-01-2012, 10:31 AM   #7
cajkat1073
+1 for above. I used 2 sats just because I had them. Flys great and less wires than using a separate receiver.
cajkat1073 is offline        Reply With Quote
Old 06-01-2012, 12:36 PM   #8
draeh
That's awesome.
Thanks!
Old 06-01-2012, 03:35 PM   #9
SQRT(-2)
Wires run from your RX to the FBL unit and then wires go from the FBL unit to the servos. That can be a mess of wires, so some people just get a Sat and run one wire form that to the FBL unit instead of having an RX and all those wires. Both work though.
You will love this new radio tech, there is no worry about having someone on your 'channel' and the glitches are very rare. Most clubs don't worry about radio impound or anything like that anymore.
Gaui Hurricane 425 FBL with Robird G31 500 Class Rocks!
EFlight Blade 450 3D, Walkera Super CP
Walkera Devo 10 w/ Deviation
SQRT(-2) is offline        Reply With Quote
