| 600 Class Electric Helicopters 600 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
Hey there!
It's been a while since I have posted... I have been swamped with work and haven't had much time to fly, work on heli's I already own a TREX 500e and, of course... I want to go bigger. I basically upgraded to the 500 so I could be more adventurous with my Blade 400. However, I find the Blade 400 so jittery and light that I don't really fly it at all... so I am still really tentative with the 500. I am getting much more bold flying my Blade MCPX - which I think is a better trainer than a simulation could ever be. I also haven't built any of my heli's and want to build one. ![]() So - I am planning to purchase and build: Align T-Rex 600EFL Pro Super Combo Flybarless Kit w/Motor, ESC, Servos, Gyro (12S) I need to buy a receiver (any suggestions?) and Batteries (Again... any suggestions?) I am not a 3Ger (doubt I will ever be) - and right now am still learning to seamlessly switch between nose in and nose out flight. Is there anything else I should think about during the purchase/build process? REALLY excited about the project!
T-Rex 600 EFL Pro T-Rex 500 ESP Blade 400 Blade MCP X |
In stock form the B400 will always stay jittery and light. It takes some work and $$ to settle them down into a great heli. But it can be done.
I assume you run a Spektrum Tx? |
Yes on the spektrum tx
If it were me, I'd consider swapping out the 3Gx and put a BeastX on it. For the RX, the Spektrum AR8000 & a satellite. Batteries are going to be tough.. the good ones are kinda hard to find right now. Gens Ace work great, Nano Tech are decent, but neither are to be found in 3300 capacity right now. You're stuck with the high priced ones from Hyperion or Thunder Power, or go with more budget oriented batteries (I'm sure other folks can weigh in on good alternatives). I'd also consider nixing the BEC and go with a 2S LiFE- I feel a lot more comfortable with this setup.
Blade 130X- My cul-del-sac flyer. Blade 450X w/MSH Brain - My Ferrari T-Rex 600 EFL Pro w/SK-720, KDE600XF & SK-GPS - My BMW T-Rex 700 HV DFC w/VBar, Kosmik 200 & KDE700XF - My muscle heli |
any 6s batter that is no larger than 155mm x 51mm x 51mm will work
I have some 4000mah sky lipos I use had to secure them with tape to the battery tray as the 51mm x 51mm part doesnt leave room for velcro
Trex 600EFL Pro V2 V-Bar ds610 ds650 cc pro bec Scorpion 130a HV KDE 600XF-530 450pro 1860kv(6s) cc50 (4 DS215MG) 10t pinion, Tarot DFC, Ikon TBS Discovery (Quad), naza-gps, 900mhz fpv, gopro2, ET OSD pro, D/L UHF X-8 Wing , D/L UHF Full fpv package |
#6 |
thanks for the advice!!
#7 |
I think maybe because this side of the hobby has taken off so strongly.
I am running a T-500 with the 3GX and Spektrum DSMX sats. There is a slight difference between it and the Vbars on my larger helis, but if they are set up correctly, I have found them to be as stable as one could ask for. I have flown both the 3G (with sensor mod) and the 3GX. I have much more time on my Vbars, but have just recently started back on my 500 with the 3GX. Good luck.
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Goblin 700, Vbar Silver - Trex 700 V2, Vbar - Trex 700DFC, Vbar Silver - Gaui X7, Vbar Silver Trex600EFL Pro, Vbar - Trex 600 ESP, Vbar - Trex 500 ESP, SK 720 - DJI 550, GPS |
#8 |
3gx is a good unit for the bigger helis but I would strongly suggest pulling it and dropping an ar7200bx in there. There perfect at the stock settings for learning to hover threw slow aerobatics on a 600. When your ready you can turn up the controller and have a fast 3d monster, its really up to you. The 3gx is great also, drop 2 satellites on there and bind it to your 7+ ch tx and go. But I find they need more tuning right out of the gate in compression with a beastx. A lot more.
You could get some cheap 3000 and keep the head speed low as to get longer flight time? Plus you dont want a ton of head speed if your learning anyway. Some one more up on the 600 pro could help on if it will balance correctly or not with the smaller packs. Nothing wrong with a bec other then just another link in the chain that can fail. I prefer a separate battery for my radio. Just have to remember to charge it once in a while. lol HTH |
#9 |
Thanks... I ended up with the AR7200bx because the 3gx I got was defective, and I didn't feel like dealing with the hassle of getting it replaced before I could fly.
I also ended up upgrading the BEC to the CC BEC Pro. I am running the separate battery for the radio - glad I went that way. It is nice to be able to work with radio with the main packs offline. She flys GREAT- so pleased with this heli.
