Go Back   HeliFreak > R/C Helicopter Support > Compass Model Helicopters > Atom 6HV
Atom 6HV Compass Atom 6HV Model Helicopter Discussion
Old 05-31-2012, 10:20 AM   #1
leaverus
Default help with delrin rod repair please
how in the heck are you guys removing the bearing to get the brass tube out without destroying the bearing?
450 Pro: hitec 65hb - outrage os7654t - spartan quark
Atom 500: mks 9670a+ - savox 1290mg - ar7200bx v3.0.8
Logo 400: futuba 9650 - futaba bls251 - mini vbar blue v5.3 pro
6HV: savox 1267sg - outrage bl9188 - beastx v3.0.8
leaverus is offline        Reply With Quote
Old 05-31-2012, 10:51 AM   #2
bostonkiter
Best advice I can give: Secure the part with a c-clamp and a few blocks of wood to a table. Position a razor blade / utility knife blade between the flange of the bearing and the housing. Tap LIGHTLY at a few different points around the flange and it should come out.
Good luck.
Goblin 700, Blade MSR. BK-117C, Sikorsky S76 C++
bostonkiter is offline        Reply With Quote
Old 05-31-2012, 11:30 AM   #3
Ah Clem
I think there is a good video on this subject.
I have heated the yoke where the bearing is pressed in, and pushed gently on the brass tube. The bearing pops right out, with a bit of heat.
KBDD-Team Pilot
Team Compass / ProStar Hobby
Gens Ace Field Representative
Warp 360, 7HV,Knight Pro,Knight 3D, Atom 500, Odin II, 6HV, 3D Plus, Knight 50
Old 05-31-2012, 01:18 PM   #4
Jason O'Connell
Formerly BarnStormer
watch this vid I made
http://www.helifreak.com/showthread.php?t=358216
"You can still call me Barn
Team Compass USA
ProStarHobby.com
Scorpion Power Systems
Jason O'Connell is offline        Reply With Quote
Old 05-31-2012, 02:11 PM   #5
leaverus
thnx for the suggestions guys. cool (or hot?) vid barnstormer.
Old 05-31-2012, 04:27 PM   #6
TheBum
Location: McKinney, TX, USA, North America, Earth, Solar System, Milky Way, Universe
For replacing broken rods, you don't even have to worry too much about how hot the yoke gets. To a point, the hotter the better. The last time I use that method this, and the only successful time, I heated it with a butane torch enough to partially melt the Delrin and the bearing came out with very little force.
HeliFreak Support
Nankin Hobby Field Rep, Compass Support Team
Helis: Compass Atom 500 (V-Bar), Compass Atom 6HV (V-Bar), Blade 130X, Blade mCPX
Experience is something you obtain only after you need it.
TheBum is offline        Reply With Quote
Old 06-01-2012, 03:43 AM   #7
Tribal69
I had to replace one too a few months ago and I used also a heat torch and a cutter knife to release the flanged bearing.
Don't use to much force on the bearing with the knife otherwise you can cut them right through.
Good luck
T-Rex 600 Nitro Pro - T-Rex 450 Pro - Prôtos 500 BeastX - Logo 400 Vbar - Compass 6HV - Compass Atom500
http://www.helicanopy.nl
Tribal69 is offline        Reply With Quote
Old 06-01-2012, 03:42 PM   #8
alexmit
I poke them out with a small diameter hex driver pushed through from the opposite end and have yet to damage or ruin a bearing. I certainly wouldn't recommend hammering on them using this method though.
Atlanta RC Club, The only club inside the city.
SAB USA Field Rep. Canomod USA Field Rep. Pulse Battery USA Field Rep.
alexmit is offline        Reply With Quote
