Old 05-31-2012, 03:58 PM   #1
torch8
Default PItch settings
Looks like the linkages to blade grips are same fix onces on mcpx, so pitch setting or setting zero at midstick must be done by rotating the servo links. I never measure pitch settings on mcpx or having to set it to zero. Wonder if this is going to be pain here. Wonder if RC Logger digital pitch gauge can fit this.
Walkera V4501
Gaui 200 V2 MicroBeastx
Walkera M120D01
torch8 is offline        Reply With Quote
Old 05-31-2012, 04:32 PM   #2
Maypole
Just put couple of bolts, toothpicks, or whatever round bodied straight edge that fits into the bolt holes on the grips as your guides and adjust away. Simple really.
Nano CP X, mCP X BL, 130 X (Love the little ones)T-REX 500 Efl Pro DFC
Phoenix Sim, DX8, Gibson Les Paul, AMA #987871
I really think this "Internet" thing is going to catch on. You can quote me on that.
Maypole is online now        Reply With Quote
Old 05-31-2012, 06:33 PM   #3
desertstalker
The RC logger weighs more than a MCPX, its way to heavy for a heli this small.
As its FBL you really dont need to be to anal about it, get the swash eyeball-level and then fold both blades to one side, if they are parallel you have 0 pitch, or close enough for this sort of heli. Pitch range I would do like a MCPX, as much as it can handle without bogging too much (or as much as you need for your flying). Precise numbers are not really needed.
-DX8
