Go Back   HeliFreak > R/C Helicopter Support > 500 Class Electric Helicopters > 500 Pro Class Electric Helicopters
500 Pro Class Electric Helicopters 500 Pro Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 05-31-2012, 07:17 PM   #1
tomd27858
Default Beast x tail precomp
Any body running precomp on their Beastx? I have a slight tail kick on full pitch pumps that I haven't been able to sort out. Now that a storm ended my flying I thought about adding precomp on the Beast x.
Team HeliDirect
Skookum Support
Flying Align, controlled by Skookum, and powered by Pulse
tomd27858 is online now        Reply With Quote
Old 05-31-2012, 11:17 PM   #2
GT86
I'm using it, it's on the low setting if I remember right. I had a very slight kick on full pitch climbs, nothing major but annoying anyway. The precomp seems to have cured it.
Sent from my tablet via Tapatalk
GT86 is online now        Reply With Quote
Old 06-01-2012, 01:00 AM   #3
what-d-heli
GT86. If you don't mind, can you check which direction it is set at? Thank you.
I want to try this precomp feature. Never used it in any of my beastx.
what-d-heli is offline        Reply With Quote
Old 06-01-2012, 06:12 AM   #4
tomd27858
Looks like I have a setting to play with if the weather holds this afternoon. Thanks Gt86. Mine is ever so slight as well but was more focused on breaking in the batteries and avoiding the thunder storm bearing down. When I made it to the garage I thought to myself that the precomp should take care of that pretty easily hence the post. I would guess most of our settings are pretty close to identical with just slight changes due to the desired feel.
Team HeliDirect
Skookum Support
Old 06-01-2012, 07:14 AM   #5
Rototerrier
Works wonderfully. On my gasser I am using the more aggressive setting. On my electric I use the minimal setting.
The direction of your tail deflection should be in whatever direction is necessary to counter the torque from the main blades.
If your Main blades spin clock wise (which most helis do) then your precomp should be set to deflect the blades to make the tail move to the left which points the nose to the right. In other words, it should precomp a right turn.
Start off with the lower setting and see if that keeps the tail solid on punch outs. Going to the higher setting will not hurt anything, so don't be afraid to test it out.
When you set it up on the bench, you can move your collective and see it pitch the tail blades. It's progressive. More pitch (positive or negative) = more precomp on the tail. 0 pitch = no precomp / neutral on the tail.
This was one of the best additions they came out with for locking in my tail. I love it.
TREX 700 Helibug GASSER 16t | µBeast | JR8717 | TRM 270TT | GV1 | R921 X9303
TREX 700 Helibug GASSER 20t | µBeast | DS610s | Hanson 29 3D Max | GV1 | R921 X9303
TREX 550 V2 DFC | AR7000 | µBeast | CC Ice 100 | CC BEC Pro | DS650 Tail | 520 Blades
Rototerrier is offline        Reply With Quote
Old 06-01-2012, 07:56 AM   #6
GT86
Mine is reverse. Set it to whatever direction you needed in the settings step F to get the tail compensating the correct way. If your normal on F you want the precomp in the normal direction, if you're reversed in F you want reverse precomp.
Sent from my Galaxy Nexus using Tapatalk 2
Old 06-01-2012, 08:00 AM   #7
GT86
The low setting worked well, and I tried the high too. Didn't notice a difference so I put it back on low. Has been fine, although I'm not a great pilot by any means so a more aggressive pilot may prefer the high setting. The precomp is a nice feature.
Old 06-01-2012, 08:03 AM   #8
GT86
+1
Old 06-01-2012, 01:12 PM   #9
what-d-heli
Thank you for the informative post guys. I'll definitely expriment with it.
Old 06-01-2012, 01:32 PM   #10
tomd27858
Great bunch of pilots over here. Everyone is always very helpful.
Team HeliDirect
Skookum Support
Old 06-02-2012, 07:50 PM   #11
tomd27858
low setting of tail pre comp fixed it right up.
Team HeliDirect
Skookum Support
Old 06-02-2012, 08:10 PM   #12
what-d-heli
Alright! So, what is the direction you had it set?
Old 06-03-2012, 01:05 PM   #13
tomd27858
My tail servo is on the right side facing the heli from the back. It turned out to be low pre comp normal direction for me.
Team HeliDirect
Skookum Support
Old 07-28-2012, 04:51 AM   #14
jabull
My tail was kicking out badly when i throw the pitch hard up and setting the tail precomp to high has taken care of most of it but it makes me think there is another issue causing the problem... any thoughts?
jabull is offline        Reply With Quote
Old 07-30-2012, 01:31 PM   #15
tomd27858
A few things to look at:
Tail authority is driven by head speed. The EFL tail performs really well at 3000.
Set up your tail to hold in rate mode. Did wonders for my Beast X and my GY520 on other helis.
Make sure everything is smooth. Tail grip bearings that are going bad can induce a lot of drag to the system.
Confirm you have the upgraded tail hub with the shims.
Run a flat throttle curve. A "v" curve causes a lot of kick issues. Learned the hard way coming up since the Align manuals always seem to post a "v" curve.
Post back on the above and we should get you heading in the right direction.
Team HeliDirect
Skookum Support
Old 08-05-2012, 02:10 AM   #16
jabull
Gonna pull the tail and check for shims.. If I don't have them, what's the best course of action
Old 08-05-2012, 06:58 AM   #17
tomd27858
Pick up the new tail hub with shims from HD would be what I would recommend.
Team HeliDirect
Skookum Support
