Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > X5
X5 Discussion and support of the Gaui X5
Old 06-01-2012, 01:02 PM   #1
tommeke
Default what to consider
Well, sold my trex 500 to get this beaty. are there things that I need to consider before I fly it? It will be equiped with align servo's and an ar7200bx. Can I get the beastx settings around here somewhere and if not, can you post it please?
Thanks for your help!
realy looking forward to flying this bird
tommeke is offline        Reply With Quote
Old 06-01-2012, 01:34 PM   #2
Chris Sexton
First off, welcome to the Grin club. The first time you fly it, You will know what I mean.
The Align servos are no problem, although there have been reports they pull more power than the stock BEC can handle. You might think about a separate BEC if you weren't already.
As for the BeastX settings, those are hard to post for you. The beastx settings are Taylored to the the heli. It will have you measure servo travel, check orientation, measure cyclic throw. All things that are going to be different from one heli to another.
I recommend just following the manual step by step. The first time through will seem a little intimidating, but once you do it once, it will be a piece of cake.
Synergy Factory Specialist / Rail Blades / Team Scorpion
Chris Sexton is offline        Reply With Quote
Old 06-01-2012, 02:26 PM   #3
tommeke
what happens if the servos draw too much power?
Old 06-01-2012, 02:28 PM   #4
Wh1teAfr1can
you have a brown out and the heli will crash. or in the best case scenario it will just glitch but the long term effect will be burning out the esc eventually and causeing a fire and or a forced auto.
Richard Zappe
Team Manager Kontronik USA Team minicopter
Diabolo Kosmik 200, Pyro 750 - 50 Comp, Diabolo S #RZ, Diabolo 550 Jive Pro 120, Pyro 650-103 Comp
Wh1teAfr1can is offline        Reply With Quote
Old 06-01-2012, 02:46 PM   #5
tommeke
isn't there a switch on the besc to let through more power?
Old 06-01-2012, 02:53 PM   #6
newbheliusr
You can adjust voltage, but not amperage. So no, you can't change a switch and get more power. A separate BEC, or a more powerful ESC/BEC is your only choice.
newbheliusr is online now        Reply With Quote
Old 06-01-2012, 02:57 PM   #7
tommeke
have guys used them with succes?
Old 06-01-2012, 02:58 PM   #8
Chris Sexton
I used the stock ESC/BEC with the stock GAUI servos, and I still had a brown out. I am currently running a WR Mini BEC, problem solved.
Old 06-01-2012, 02:59 PM   #9
tommeke
damn, again extra costs :p
Old 06-01-2012, 03:04 PM   #10
newbheliusr
I use a CC BEC Pro on mine, along with a CC Ice 100. Separate BEC always adds a bit of security IMO
Old 06-01-2012, 03:25 PM   #11
tommeke
if you use a seperate bec, will you need a LiFe pack or can you run it fram the normal pack?
Old 06-01-2012, 03:56 PM   #12
newbheliusr
I run it right off the flight pack.
Old 06-01-2012, 03:57 PM   #13
Chris Sexton
That is up to you. I tied mine into the flight pack, less weight. No measurable decline in flight times.
Old 06-01-2012, 04:14 PM   #14
tommeke
are there cheaper bec's than WR?
Old 06-01-2012, 04:25 PM   #15
Chris Sexton
CC BEC Pro V3, 38.99, works great on 6S.
Just don't get the blue BEC by Castle, it's weaker than the stock ESC.
http://www.experiencerc.com/store/ca...ro-p-9891.html
Old 06-01-2012, 04:34 PM   #16
helidude71
Keep in mind what will happen if your BEC fails.
TSH Gaui X5 FES, Spirit, S.Bus, HW100A V3
TSH Gaui X3, Spirit, 6S, S.Bus, HW50A V3
Futaba T7C (I admit, also a Spektrum DX8 and some planks.) ;-)
Phoenix R/C v5
helidude71 is offline        Reply With Quote
Old 06-01-2012, 04:46 PM   #17
dodgeboy
+1
i have it on my 12s fusion 50 and it works just fine
dodgeboy is offline        Reply With Quote
Old 06-01-2012, 05:08 PM   #18
newbheliusr
Just don't run it off 12s. Run it off 6s max.
Old 06-01-2012, 05:14 PM   #19
tommeke
it's for an x5 so it will be 6s
Old 06-01-2012, 05:26 PM   #20
newbheliusr
I've got mine setup, and it works great.
