Go Back   HeliFreak > R/C Electronics Support > HobbyWing ESC's
HobbyWing ESC's HobbyWing ESC Support
Old 06-04-2012, 03:27 AM   #1
jchen
Default HW 40 ESC help
Hi All,
Need alittle advice. Installed the above in my Mini Titan FBL. Using internal BEC to
power the align servos. Heli flys well but strangely on pitch pumps its very slow to react.
On bench collective functions well. Pitch set at 10 deg will no binding of the links. Is it
possible that the 3 amp internal bec is insufficient to power all 3 servos under load ?
Thks
jchen is offline        Reply With Quote
Old 06-05-2012, 11:09 AM   #2
BennyTRD
I'm using the the same ESC on my Mini Protos without issue. BEC seems to be keeping up with my power needs.
Do you have the Platinum version? What's your BEC set to (5.5 or 6V)?
One test would be hook up an external BEC and see if your problem persists.
Logo 600SE - 12S, 693's, VBar ---- Logo 6003D - 12S, 623's, VBar
Logo 400SE - - 6S, 473's, VBar-------Raptor E720 - 12S, 713's, VBar
BennyTRD is offline        Reply With Quote
Old 06-22-2012, 07:33 PM   #3
SidewaysLS4
I'm running 4X DS95/DS95i w/vbar on the Platinum's BEC...seems great so far
SidewaysLS4 is offline        Reply With Quote
Old 08-03-2012, 04:56 AM   #4
Milo.
Running 3x MKS DS92A+ and 1x DS8910A+ at 6V from the internal BEC (3A) without any problems.
Milo. is offline        Reply With Quote
