Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > 120 SR
120 SR Blade (eFlite) 120 SR Helicopters Information and Help
Old 06-06-2012, 11:50 AM   #1
Laynelin
Default Want to upgrade motor and battery, any idea?
I want to upgrade the motor and battery.
Basically I want a more powerful motor (is Xtreme motor a good one?)
And I want a bigger battery, I can accept even to replace a bigger battery tray to get a 800mhA or even bigger battery.
Any good recommendation?
Laynelin is offline        Reply With Quote
Old 06-06-2012, 02:29 PM   #2
koi-fish
Yep...get the extreme motor, I have it and it really woke this bird up..........As for batts, I use the stockers at this time, though I occasionally use the 600 mah that my mcpx brushless uses as well
/MSRX, MCPX, Nano, 1SQ, several 130x, Gaui X2, 300x, 450x, DX8, Harley Road King
"It's not getting any smarter out there, you have to come to grips with stupidity and make it work for you" - Frank Zappa
koi-fish is offline        Reply With Quote
Old 06-06-2012, 04:06 PM   #3
Heli-cat
and then hook it up to this
http://www.rc711.com/shop/raiden-37v...l?cPath=280_30
Heli-cat is offline        Reply With Quote
Old 06-07-2012, 05:49 PM   #4
Laynelin
This 1300mhA battery looks cool. But how can you mount it to the heli? Do you mod the battery tray?
Old 06-07-2012, 05:51 PM   #5
Laynelin
This 1300mha battery looks good. But how do you mount it to the heli? Do you mod the battery tray?
Old 06-07-2012, 07:59 PM   #6
Heli-cat
I'm using this http://astroid-designs.myshopify.com/collections/120sr
but it's currently out of stock. You'll either need to modify the stock one, purchase the RKH mount, improvise your own or wait until these come back in stock.
The Astroid one works great for me....been using it with the 1300s for a year.
Old 06-15-2012, 12:57 PM   #7
mdbsat
I am very to new RC helicopters and have had my 120 SR for about a week and a half. I am still trying to learn how to fly but I am addicted to modding, changing anything I own...much to my wife's chagrin. I have turned my Mini Cooper S into a beast but thats for another forum.
If I am just learning to fly would it be too soon to but this Xtreme motor for my bird?
mdbsat is offline        Reply With Quote
Old 06-17-2012, 07:31 PM   #8
themadnewfie
if I had to do it again .. I would have gone down the same path .. Just would have gone there faster
go for durability first
I broke 2 things to start (not counting landing gear which is just comical)
1. Battery Cage - you don't need to be an engineer to know that part is at risk
2. Tail Motor Mount - maybe it was just me ... But they were not designed for impact
get the tray from android designs .. And never look back
I went the micro heli path .. But either way its a solid upgrade
then you can practice and get better to then buy parts to make you go faster
themadnewfie is offline        Reply With Quote
Old 06-18-2012, 10:49 AM   #9
mdbsat
Thanks! I will get it now. I ended buying an mCX2 this weekend because I just wanted to fly SOMETHING. I spend so much time either fixing, soldering or buying new Tail Motor Mounts, Tail Motors and that darn little black bearing on the tail in between blade and motor so I know what you mean by "not designed for impact." Also, two weeks in I am just not a very good RC Heli pilot yet Thanks for the reply.
Old 06-19-2012, 03:56 PM   #10
Maxoni
I'm a newbie myself ,I learned the hard way and bought a CP Sr first big mistake, I worked my way up to the 120 kinda got bored flying indoors and hearing my wife complain everytime I buzzed around her head with MSR I'm almost ready to upgrade heli with parts for better performance. You can't go wrong with advice from previouse post. Keep flying skill level will come with time
CAN"T STOP FLYING
T-REX 250, 130X , BLADE SR , SR120, MSR, MCPX Dx6i
Maxoni is offline        Reply With Quote
Old 07-14-2012, 01:37 PM   #11
Mike-will-sk8
Default Different beast and flight time
I set goals for myself with the stock 120 SR before upgrading, Told myself I must be able to fly 3 times in a row with no crashes, be able to chase myself with nose in hovers through my house or visa versa, and figure 8's both ways. This is my heli now
Like you said about your mini cooper, It is a completely different beast than the stock.
I have been having serious issues with weight and flight time however. I get maybe 3 minutes with stock and protech 550 batteries before it decends to hover just an inch off the ground. If anyone could point me in the direction of a good battery, Id appreciate it
Mike-will-sk8 is offline        Reply With Quote
Old 07-14-2012, 05:47 PM   #12
DogsOFdoom
Which blades are those?
Galaxy note Paranoid Android 1.7ghz goodness
DogsOFdoom is offline        Reply With Quote
Old 07-15-2012, 03:44 AM   #13
Heli-cat
Old 07-15-2012, 08:40 PM   #14
jaybird111
At one time I was going to get all kinds of upgrades hoping to make my heli less breakable and fly better. As it turns out my flying skills have taken care of the breakage problem and it seems the weight issue hinders speed and maneuverability. So I will continue to fly stock and when it does happen I will replace broken parts for a couple of bucks.
JayBird
I love to Fly every day
(2) 120sr's ...One Max Axe cp 2.4 and a Trex 250
A Dx6i and a stock pile of parts
jaybird111 is offline        Reply With Quote
Old 07-16-2012, 01:23 AM   #15
Mike-will-sk8
Default blades
They are stock, I just painted them red with gold tips to match the red rakon/carbon fiber look
Old 07-16-2012, 11:09 AM   #16
Glaucon
Did you balance the blades after painting? Paint adds weight as I have found out myself
Glaucon is offline        Reply With Quote
Old 07-17-2012, 12:50 PM   #17
Mike-will-sk8
Default eh
Nah i don't care to much about the little bit of weight some paint might add and the heli flies just as good as it did before and looks rad as the blades spin up
Old 07-17-2012, 02:36 PM   #18
KYCHOPPER
Default Awesome mods!
Mike, your mods look awesome, can you list them and how much you have expended on them? How about a pic with the canopy in place?
Have you found any solutions to the weight issue?
Can't wait for IRCHA!
KYCHOPPER is offline        Reply With Quote
