Go Back   HeliFreak > R/C Electronics Support > HeliCommand
HeliCommand HeliCommand Support
Old 06-07-2012, 08:15 AM   #1
rchflyer
Default sinus linearizer ?
I see the default is 5, and read that is typical for 3-servo 120 setups.
I am running BLS252 servo's and I have set everything to 90 and even/level. If I run the SL @5 my rates are in the 65-75 range. For testing on the bench, if I change the SL to 0, my rates drop into the 50 range. So what is best??
I also notice my BLS251 also does a lot of clicking ie: acting like it is resetting on the bench, is this normal??
Thanks,
Dennis
rchflyer is offline        Reply With Quote
Old 06-07-2012, 12:19 PM   #2
F1 Rocket
Hi Dennis,
Sinus Linearizer (could there be a more terrible name) is used to compensate for uneven servo travel, primarily on 4 servo swashplate setups where binding can happen. 5 usually works best for 3 servo setups.
Danny
F1 Rocket is offline        Reply With Quote
Old 06-14-2012, 09:55 AM   #3
Joachim HC
Originally Posted by F1 Rocket View Post
Sinus Linearizer (could there be a more terrible name)....
There was no recommendation from you, Danny ....you know we would have changed it
CAPTRON Electronic GmbH
- HeliCommand Support Team -
Joachim HC is offline        Reply With Quote
Old 06-14-2012, 10:09 AM   #4
F1 Rocket
I know, I know. I wasn't in a very creative mood. maybe we can have a "Rename the Sinus Linearizer" contest. The winner gets a new............................................... ....?
Danny
Old 06-20-2012, 04:33 AM   #5
Joachim HC
........................USB-Stick?
In case someone has a great idea, feedback is appreciated anytime.
Joachim
Old 06-20-2012, 07:44 AM   #6
popokatepetl
How about "servo travel compensation".
It's clear isn't it?
popokatepetl is offline        Reply With Quote
Old 06-21-2012, 02:33 AM   #7
eylau2005
Joachim
SSTS = Swash plate (because it is only SW servos) Servo Tavel Straightener
(the later is a device for removing curls from hair) here we are removing curls from Servo end travel points and it figures the concept ........ some humor make the flight more linear.. isn't it? Piero
eylau2005 is online now        Reply With Quote
Old 06-22-2012, 06:03 PM   #8
TomC
I like it!
Or, maybe 'Servo Travel Equalizer'
Cheers,
TomC
Blade mCPX-BL,300x,450x,500x,550x(hc3sx)
Logo14, 550 blades
TT X50E, 10s, HC3-SX
TomC is offline        Reply With Quote
