Go Back   HeliFreak > R/C Helicopter Support > Synergy Model Helicopters > Synergy Nitro Models
Synergy Nitro Models Synergy Nitro Models Support
Old 06-07-2012, 01:06 PM   #1
flyboydave
Default N5c canopy stand offs
Just building my model and i'm unsure about the canopy stand off's. Ones a little shorter than the other, I take it the longer one goes in the rear position as the instructions re not that clear?
flyboydave is offline        Reply With Quote
Old 06-07-2012, 05:18 PM   #2
Flat Eric
Short ones on the front, long ones on the rear.
Awesome heli Enjoy
Flat Eric is offline        Reply With Quote
Old 06-07-2012, 06:18 PM   #3
flyboydave
Looks good so far :-) Its replacing a velocity 50 n2 which I was not to keen on some of the parts quality... Any tips? :-)
Old 06-07-2012, 07:13 PM   #4
jgalen0025
make sure you pay particular attention on setting the phasing arms or your heli will not fly right.
Also depending on the servos(cyclic) you use, make sure the links are not angled in in any way. As in they should be exactly paralell to the frame
If your using full size vbar you can mount the sensor behind the main shaft with a metal plate(sk720 plate) mounted across the frames.(way less vibrations back there)
You might want to try 620mm blades, this heli is a little heavier than other helis and these will give you more lift and better autos.(only if your using 55 or bigger motor)
To set belt tension get the heli ready to fly with full fuel tank and canopy. Loosen the tail assembly, grasp the tail assembly and hold the heli upside down at the same time tightening down the tail assembly on boom. This sets perfect belt tension.
It is easier to wire everything up with the front radio tray off
Any other ?s let me know
US Army VBAR PRO GOV
MA Fury 55 Whip Nitro 105
Whip Nitro (2) FOR SALE
jgalen0025 is offline        Reply With Quote
Old 06-07-2012, 07:17 PM   #5
drdispatch
Check the Synergy website's forums tips & tricks section for the n5c.
Synergy N5c YS56, CGY750
Gaui X5 Vbar
MSH Protos Vbar
Blade 130X
drdispatch is offline        Reply With Quote
Old 06-07-2012, 07:19 PM   #6
drdispatch
There's a new Synergy swash tool for the n5/e6/e7 that helps set the phasing arms exact.
fblrotors.com has them
I'm trying my 750 sensor on the servo block - I bet the new silver would fare well there too.
Gaui X5 Vbar
MSH Protos Vbar
Blade 130X
