Go Back   HeliFreak > R/C Helicopter Support > Multi Rotor Helicopters
Multi Rotor Helicopters Multi Rotor Helicopters Info and Support - Tandem, Quadcopters, Tricopters, Octocopters, and Hexacopters
Old 06-07-2012, 05:23 PM   #1
jmc67
Default KK board questions - setup
So I got the KK black board version 5.5 (Atmega 168PA). I think firmware version 2.5 (x) is loaded and I also have the USBasp programmer. I have a few questions since I'm not familiar with this board.
1. Is there a way to tell what firmware is loaded on the board?
2. What flashtool is recommended? I have kkmulticopterflashtool v0.62 and AVR Studio 4. AVR is giving error when trying to select programmer. The other flash tool loads.
3. Can the board get damaged if you set the wrong settings upon flashing?
4. Is there a difference in firmware between blue and black?
jmc67 is offline        Reply With Quote
Old 06-07-2012, 11:58 PM   #2
petedee
1. Possibly but I have never bothered just load what you want to try next.
2. Use KK or Extreme Burner.
3. Highly unlikely.
4. Choose the firmware from the list in KK according to your board and you can't go to far wrong, most I think now like 4.7 from Kaptain K or 2.5 from Minsoo Kim.
DJI Naza 330, 450 & 550 hexa, TBS Discovery (Naza-M/5.8Ghz vid link/ET telemetry), KK2 micro hexa and micro quad, Nano Ladybird/Spektrum Hybrid, Nano MQX hybrid.
300X, Trex 450 Pro DFC, mCP X's, mSR X, nano CP X
DX18, 14SG
petedee is online now        Reply With Quote
Old 06-08-2012, 04:25 PM   #3
bstanley72
This might help:
http://flitetest.com/articles/HK_Qua...er_Programming
I watched it last night, I believe they said it is the KK board.
Compass Atom 500, DJI 450 Flame Wheel, mCPX Brushless, Nano CPX, T-28 Trojan, "Crash Proof" Hawk Sky, DX8, overinflated sense of self worth!
bstanley72 is offline        Reply With Quote
Old 06-09-2012, 08:23 PM   #4
jmc67
Very informative video, thanks. I loaded fw 4.7 from a hex file (taken from rcgroups) with no issues. Everything is setup but have a very small oscillation from forward flight to a hover. My pots settings are roll 40%, pitch 0% and yaw 50%.
Does anyone know if firmware v4.7 supports changing flight mode with the tx like you can with v2.5?
What are the differences between the different modes?
Old 06-10-2012, 08:07 PM   #5
petedee
I would have thought you would need more than 0% on pitch, especially considering you have an oscillation during transition to FF.
DX18, 14SG
Old 06-10-2012, 08:44 PM   #6
jmc67
I tried setting the roll (P) and got it where it hovers nice and also set it for forward flight so that it does not pitch up using pitch (I) but still get a slight oscillation coming to a hover. The quad is/was a Walker UFO MX400. All electronics removed. Here is the setup.
Original Walkera MX400 frame, motors and props.
KK board v5.5 running firmware v4.7
Power distribution board
Hobbywing FlyFun 30A Brushless ESC
Spektrum AR600 rx
Spektrum DX7 tx
ID:	323575   Click image for larger version
ID:	323576   Click image for larger version
Old 06-15-2012, 05:06 PM   #7
Spork01
Spektrum AR600 rx
Spektrum DX7 tx
Hello JMC67, can you take another close up pic of the wiring from the receiver to the board please? thanks!
Trex 450 Pro V2 FB spartan quark
trex 250 beastx
Fusion 50 beastX
Spork01 is online now        Reply With Quote
Old 06-15-2012, 11:45 PM   #8
bobepine
did you calibrate your ESCs? Individually using the RX and all at once using the TX?
Chris
bobepine is offline        Reply With Quote
Old 06-18-2012, 12:36 PM   #9
jmc67
Yes, I think its a matter of setting the pots correctly.
Chris
Old 06-18-2012, 12:44 PM   #10
jmc67
I would but I don't have this board hooked up at the moment. I'm trying out another board (FY-90Q) on the MX400 frame. Attached is another image. Hope this one works for you.
Old 06-18-2012, 03:26 PM   #11
petedee
Those FY-90Q boards look interesting with lots of features, how is it going? I would try one but currently using four different boards already....
DX18, 14SG
Old 06-18-2012, 08:09 PM   #12
jmc67
Should be ready for flight this weekend.
Old 06-19-2012, 09:32 PM   #13
pinguin
Try using several layer of foam tape to mount the board, rather than using screws.
pinguin is offline        Reply With Quote
Old 06-24-2012, 11:04 PM   #14
jmc67
FY-90Q board is not bad at all. It does a good job auto leveling but sensitive to vibration. If you have a perfect setup, this board does its job. Since I have the KK board and now waiting for the KK2, I will more than likely sell the FY-90Q. I've only had it for almost 3 weeks.
Old 06-24-2012, 11:05 PM   #15
jmc67
I changed the walkera props to 1045 blades and the oscillation disappeared.
