Old 06-08-2012, 10:48 PM   #1
sly the dogman
Default Advance servo buffer harness
I have Futaba so I bought the "y" harness, advance servo buffer, they call it.
Do I install this on elevater or aileron channel on the Rx. Now when I set the
programmer I hope it gives me the option of PCM. because I only see PPM in the vids.
We do accept FB parts for Compass 5.5
sly the dogman is offline        Reply With Quote
Old 06-09-2012, 12:40 AM   #2
Tim Marks
Hi:
You do not require 605SB when using CPII, only CPD4. You purchased CPII, right?
Tim Marks
Tim Marks is offline        Reply With Quote
Old 06-09-2012, 10:19 AM   #3
sly the dogman
Yes I did !
I was sure it was in relation with the CP2. Do you think I will be able to have this items refunded.
In its place I would buy a FUIM3 PC interface, is this the unit that you download the HD module with.
You see, I'm a french canadian and my first language is apparently not english.
I need guidance here, I bought a Combo # 2 / CoPilot2.
Any help will be appreciated
Old 06-09-2012, 01:32 PM   #4
Tim Marks
Yes I did !
Hi:
Yes, you may return the 605SB and pick up the FUIM3. Please contact Cindy in sales:
cindy@fmadirect.com or
Ph (301) 798 2770
Tim Marks
