Go Back   HeliFreak > Multi Rotor Support > Main Forum - Multirotor Talk
Main Forum - Multirotor Talk General Multirotor Support
Old 06-09-2012, 11:59 AM   #1
AKPhill
Default anyone have an idea what happened
KK board
Well had trouble with my esc's so I ordered new ones and hooked them up.
Was setting tx throttle ranges and the board just quit
no throttle response, can't arm the board motors just beep at me
lowered my trim setting on throttle still no go.
hooked each esc and motor by themselves and set tx throttle and all motors work but nothing when hooked to the board
The board came flashed for x quad and is what I am setting up for
Maybe someone has an idea hope so
If you need more info please ask as I am new to these quads
AKPhill is offline        Reply With Quote
Old 06-09-2012, 03:04 PM   #2
petedee
Try re-flashing the board.
similis vobis fugere eam furatus
"The beatings will continue until morale improves."
-- William Bligh
petedee is offline        Reply With Quote
Old 06-09-2012, 04:09 PM   #3
AKPhill
Been trying to that very thing
Trying to download the usbasp drivers
Can get them to run in windows 7 64 bit but cannot get the flash tool to run in widows 7
Can get flash tool to run in xp 32 bit but cannot get usbasp to run in xp
Tried it in 32 bit and 64 bit operating systems not having much luck
Old 06-10-2012, 08:12 PM   #4
petedee
For Win7 64bit if you have loaded Java using a 32 bit browser the KK tool will not run, you must use a 64 bit browser like Internet Explorer 64 bit to load 64 bit Java, this held me up for a while. What version of KK tool are you trying to run, if it is one of the newer ones try going back to version 0.53.
There is a couple of the 32 bit driver versions around, try another one making sure you completely uninstall the old one first.
Good luck.
Pete
-- William Bligh
