| Odin and 3D+ Compass Odin and 3D+ Model Helicopter Discussion |
as above i have been through 3 new clutch bearings.why is this happening?!
I would dismantle the fan and clutch to check if something is out of order, sounds like I heard a couple of years back where something was placed upside down in there so bearings and clutches were eaten raw. Double check to manual
Klaus Myrseth Team Compass 7HV FBL fullsize VBar - 3Dplus FBL fullsize VBar - Atom 500 FBL mini VBar JR 11X <3 - KBDD |
The clutch stack block should be mounted with the smaller cut out pointing towards the front of the heli, but if you have that backwards your gear mesh would likely be all screwed up and you would notice it pretty quick. Just throwing it out there.
What kind of starter are you using? Does it "hammer" alot? I have had two clutches break, but no issues with the one way bearings.
Airtronics SD10G, SK540, Novarossi .57 3DS Synergy N5C Build in progress! MAAC #85462 |
#4 | |
Atlanta RC Club, The only club inside the city. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. SAB USA Field Rep. Canomod USA Field Rep. Pulse Battery USA Field Rep. |
