Go Back   HeliFreak > R/C Helicopter Support > Compass Model Helicopters > Atom 6HV
Atom 6HV Compass Atom 6HV Model Helicopter Discussion
Old 06-10-2012, 07:58 PM   #1
aja1216
Default 80HV Settings
Anyone running an CC 80hv with a the stock motor?
If so can you please post you settings please.
Thanks,
AJ
aja1216 is offline        Reply With Quote
Old 06-11-2012, 12:20 AM   #2
Larry227
I'm running the HW esc that came with my kit but some of my settings may help.
http://www.helifreak.com/showpost.ph...59&postcount=2
You can also check post #3 in this thread http://www.helifreak.com/showthread....ht=motor+poles for more info.
Wish I had more precise answers but those two threads are the closest I can find. At least it gives you a little info to start with.
Compass 6HV - SK540 - MKS HBL665/669
Trex 500 ESP - SK540 - 510's/BLS251
DX8 / Phoenix / Persistence
~"See the heli, fly the heli"~
Larry227 is online now        Reply With Quote
Old 06-11-2012, 08:32 PM   #3
aja1216
Thanks Larry!!! On my CC I'm running 12khz PWM with 5 Degree timing and the motor is coming down hot. From what I read looks like I have to raise it to around 15-18.
Thanks a lot!!!
AJ
Old 06-11-2012, 08:52 PM   #4
RCTada
I have 22.5 on my hobbywing 70hv seems to be doing the job. Will try 18.75 not sure yet.
Sent from my DROID BIONIC using Tapatalk
RCTada is online now        Reply With Quote
Old 06-15-2012, 06:58 AM   #5
PieroCapredoni
Default CC 80HV setting
Hi, Im using OUTRUNNER MODE and 18deg timing in my CC 80HV. Works perfect, no temp problems, good power. I fly sport and light 3D only.
HK/Trex 450 ProFBL, Atom 500 FBL, Trex 500 FBL Hughes 500D, Compass 6HVFBL, Trex 600 EFL Pro
PieroCapredoni is offline        Reply With Quote
Old 06-15-2012, 09:02 AM   #6
aja1216
I'm going to try that out!!! What headspeeds are you running on your gov?
Thanks bud
AJ
Old 06-15-2012, 09:57 AM   #7
sarpilot
Thanks,
AJ
I have the 80HV and stock motor but 11T pinion for 2150 in Idle2. If you want those numbers post back.....
"It's not the crash so much as the sudden stop"
Alees Rush 750, Compass 7HV, Compass 6HV, TRex450Pro, Blade MCPX, bunch of other junk in boxes
sarpilot is online now        Reply With Quote
Old 06-15-2012, 03:00 PM   #8
aja1216
I would love those number!!!!
THanks Bud!!!!
Old 06-16-2012, 07:10 AM   #9
sarpilot
THanks Bud!!!!
OK gotta work today but when I get home tonite I'll plug it into castle link and post the settings for you…
Sent from my DROID3 using Tapatalk 2
Old 06-16-2012, 05:43 PM   #10
sarpilot
Here ya go.....
# Castle Link Data File
# Created: Saturday, June 16, 2012
# Do Not Edit This File By Hand
Hex55: 85
Brake Delay: .6 sec (Delayed) (*)
Brake Ramp: Immediate (*)
Cutoff Type: Soft Cutoff
Motor Start Power: 39
Direction: Forward (*)
Brake Strength: 0
PWM Rate: 12 Khz (*)
Cutoff Voltage: Auto Li-Po (*)
Current Limiting: Disabled
Sample Frequency: 5 Sample / Sec
Power-On Beep: Enabled (*)
Auto-Lipo Volts/Cell: 3.2 Volts/Cell (*)
Motor Timing: 18
Data Log Enabled: 255
Vehicle Type: Helicopter
Throttle Type: Governor Mode
Throttle Response: 5
Governor Gain: 25
Initial Spool-Up Rate: 2
Head Speed Change Rate: 5
Auto Rotate Enabled: True
Governor Mode Type: Fixed
Vehicle Setup - Battery Type: LiPo
Vehicle Setup - Number of Cells: 12
Vehicle Setup - Battery Voltage: 44.4000
Vehicle Setup - Gear Ratio: 9.454
Vehicle Setup - Motor Kv: 540
Vehicle Setup - Motor Number of Poles: 8
Desired Head Speed 1: 1956
Desired Head Speed 2: 2052
Desired Head Speed 3: 2159
