Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > mSR
mSR Blade (eFlite) Micro SR Helicopters Information and Help
Old 06-12-2012, 03:00 PM   #1
wulfrun
Default Substitute tail motor?
Ok, so I used to have some shrink-tube over the tail motor and it came off. I didn't get around to replacing it and the inevitable has happened - yep, knocked the end-cap off the motor! Lesson learned!
Anyone used a different motor and if so what? I'd rather not replace the who lot for the sake of a motor and I'm not scared of the soldering involved. Just to add, I'm in the UK so may not have access to the range of stuff in the U.S.
Out of interest, the motor's had a heap of use over 18 months and showed no signs of being worn out. The commutator is un-worn and the brushes likewise (but they got twisted up in the spill).
Belt CP/Blade 400 hybrid with RDTS mod
Blade mSR, Blade mSR-X, Blade mCP X (V1), Blade Nano
Buzzfly BE (aka Walkera 4#3B)
wulfrun is offline        Reply With Quote
Old 06-13-2012, 05:37 PM   #2
Pfloyd
Get a tailboom with motor for the mcp-x...make sure to get the longer tail/boom.
MCX/MCX2/MSR/MSRX/MQX/C105B/S300/MCPX/S107G/S107C/S109G/S108/S026/S009G/S023G/S102G/S110G/GYROPTER/
AIRRECON/UDI-803/UDI-816A/SYMAX1/V959/JXD-355/052INTERCEPTOR/EYE1/S113G/UDI-U810/
DX7s
USAF RETIRED (1968-1988)
Pfloyd is offline        Reply With Quote
Old 06-14-2012, 10:40 PM   #3
koi-fish
I'd think you'd have problems with tail blowout with the bigger motor. That isn't the case?
/MSRX, MCPX, Nano, 1SQ, several 130x, Gaui X2, 300x, 450x, DX8, Harley Road King
"It's not getting any smarter out there, you have to come to grips with stupidity and make it work for you" - Frank Zappa
koi-fish is offline        Reply With Quote
Old 06-15-2012, 04:46 AM   #4
wulfrun
I was under the impression that the mSR X or mCP X tail has a more powerful motor and I don't think the mSR needs a longer boom. What I was really after was an equivalent motor-only option.
Old 06-17-2012, 09:39 AM   #5
Luftwaffel
This: http://www.banggood.com/Wholesale-Mo...5-p-41995.html
v1 mCP-X / mSR / DX6i / 9958 / v911
Luftwaffel is offline        Reply With Quote
Old 06-28-2012, 08:12 PM   #6
hydro_pyro
The mSR doesn't need a longer boom. It throws off the center of gravity badly. If the motor is good, the tail will NOT blow out, even with punches of full throttle climbing.
If the stock tail boom is not available, you can use the mCX2 drive motor with the same blue and red colored wires. It's the same motor. DO NOT use the reverse rotation mCX2 motor with the black and white wires, it's designed to spin the other way and it will burn out quickly if you run it backwards.
Modified Blade mSR
UM P-51 Mustang
UM Sukhoi SU-26XP
hydro_pyro is offline        Reply With Quote
Old 06-30-2012, 06:28 AM   #7
wulfrun
+1, I wasn't looking to extend it and agree it isn't a good idea.
That's the answer I was looking for, thanks. I broke the motor and nothing else, so it seems a waste to replace the whole lot. Presumably you mean the mCX2 main rotor (1 set) motor? Doesn't that come with a pinion on it and if so what's the best way to remove it?
Old 06-30-2012, 06:40 AM   #8
hydro_pyro
Usually you can crush the pinion into pieces with a pair of heavy wire cutters squeezed between the gear teeth.
Modified Blade mSR
UM P-51 Mustang
UM Sukhoi SU-26XP
Old 06-30-2012, 11:24 PM   #9
Pfloyd
I have a longer boom on my msr-x. Actually it is the tailboom/motor from an MCP-X v2.
Turns much better and handles much better.
DX7s
Old 07-04-2012, 04:05 PM   #10
wulfrun
mSR X is a rather different bird. I've never had issues with the stock tail on the mSR.
