| Gryphon Electronics Gryphon Electronics Factory Support Forum |
Good afternoon,
we would like to say a BIG THANKS to William James, who opened a Gryphon Electronics and a Gryphon Rotor Blades section on Helifreak. This will help us to centralise any issue encountered by our customers, answer the various questions, announce the new products and grab the customers products improvement suggestions. Please do not hesitate to contact us on this forum for any question you would have Thank you very much, Fabien and HeeChull |
I recently got a pin flag switch with the LED failsafe, and was wondering where the single wire plugs into. It has 2 plugs, and I know the plug with three terminals plugs into the switch channel, but where does the other plug with one terminal plug into? I thought it was the aux channel, but I just want to be sure.
SAB Goblin 500
Avant Aurora E To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
Hi,
yes, the single wire plug goes into the " AUX " plug of the Gryphon regulators. Please just make sure you are using a Gryphon GVR or GSR model The Aux is for the low voltage alarm to lighten / blink the onboard led of the failsafe switch with integrated low voltage led, if you have any doubt, just let me know and i will post a picture of it. Here is an aexample on a Vega regulator : ![]() Best regards, Fabien |
got it. thanks a lot!
SAB Goblin 500
You are welcome
#6 |
Hello, I have a question for the schematic drawing on the gryphon gvr7020 manual for the servo 1,2,3,4 connector.
What is the correct order number for connecting the 4 servo hv that I have on my helicopter? I have a hv align servo bl750 n 3 bls700, is it no.1 for aile, 2 for elev, 3 for pitch n 4 for rudder? Thank you in advance.
Trex700E DFC HV 3GX V3.1 Super Combo GVR-7020S Trex600EFL Pro 3GX V3.1 Super Combo Trex450SE-V2 FBL Tarot ZYX JR XG7 |
#7 |
It shouldn't matter what order they go As long as what servo you have going in as 1. comes out as 1 same thing with 2,3 and 4
#8 |
Thank you frito
#9 |
I just purchased the GVR 7020 and am trying to understand the proper wiring sequence for using the GVR 7020 with a Spektrum AR8000 receiver and the Helicommand HC3sx.
Would it be attaching the HC3 with the cable loom to the AR8000 and the the HC3 servo out to the Gryphon receiver in and then the servos connected to the Gryphon servo ports?
--Jim-- mCPx v2 --- Align Trex 500E HC3sX --- Align Trex 700E HC3SX --- DX8 AMA 1009579 |
