Go Back   HeliFreak > R/C Helicopters > Newbies: Tips and Information
Newbies: Tips and Information Section of HF, specifically for Passing along info to newcomers to the hobby. Setup, tweaking, orientation practice, etc.
Old 06-15-2012, 02:45 AM   #1
sprat0864
Default ESC coil in reciever wire ???
Does anyone know if the coil in the middle of the reciever wire on some ESC,s has a function or is just to shorten the lead somewhat ??? I am setting up a 500 and the throttle wire is a bit short so i was going to remove the coiled up part but i noticed that it appeared to have been done like that before the ends were pressed.. Am wondering if that is done for some kind of electric field disturbance or something ??? Any thoughts much appreciated ta .. Cheers from down under
sprat0864 is offline        Reply With Quote
Old 06-15-2012, 06:42 AM   #2
AngSop
The ferrite ring is an electromagnetic interference device. It prevents the electrical 'noise' from the ESC from entering the receiver.
Blade 400,mSR,mCPx
T-Rex 450 Sport/500/550/600N/600EFL Pro
DX6i/11X
AngSop is offline        Reply With Quote
Old 06-15-2012, 08:59 AM   #3
GunnyGlow
2.4GHz systems don't really need it. You can either break the ring by squeezing it with needle nose pliers or pull the pins from the connector and taking it out.
DROID/Tapatalk2
GunnyGlow is offline        Reply With Quote
Old 06-15-2012, 09:45 PM   #4
sprat0864
Thanks heaps for that info. I have 2.4 gz so will break it off.. Cheers for that guys :-)
