Old 06-16-2012, 10:40 AM   #1
Airscrew
Question Dx7s or Dx8 w/720 question about frame rate
Hi, Is anyone out there running their 720 with the Dx7s or Dx8 on 11ms frame rate with ONLY the 2 Sats (DSMX) ? Was wondering if you still need the larger main Rx such as the AR8000 or the AR10000 with (or without) the Sats to actually get down to 11ms . . . Thanks
Airscrew is offline        Reply With Quote
Old 06-16-2012, 10:45 AM   #2
ArguZ
22ms , 2 sats, one left, one right side of the frame.
150 flights, never a loss or hold.
ArguZ is offline        Reply With Quote
Old 06-16-2012, 11:30 AM   #3
georgi UK
=] no external receiver needed, both sat's plug directly into the SK ports, select DMS2 or DSMX mode, it will only bind to the Tx protocol being used....
georgi UK
georgi UK is offline        Reply With Quote
Old 06-16-2012, 12:35 PM   #4
NRPY
I use a DX8 with two DSMx satellites. I bind at 2048 res and 11 ms. Works great.
You don't need an extra receiver.
NRPY is offline        Reply With Quote
Old 06-16-2012, 12:46 PM   #5
Airscrew
Thanks much ! ! !
Old 06-17-2012, 02:46 PM   #6
soko
Me too...
DX8, two DSMX sats, bound @ 11ms 2048.
Works great: But just make sure after everything is setup properly in the software you rebind the whole thing at the last step. Otherwise you could get a ratched tail-servo movement...
Soko
ONE TOOL for ALL SIZES and ALL BRANDS
"Unique features" | "Awesome setup tool" | "its simply awesome"
www.soko-heli-tools.com
soko is online now        Reply With Quote
Old 06-18-2012, 07:48 PM   #7
johnahamelv
I was originally using the AR8000's mainly to monitor the antennae signals health via the TM1000. However, by using the AR8000 Rx, I was giving up a lot of the functionality of SK-720, and I needed to plug more wires to the SK-720 which adversely affected sensed vibrations. Since switching to just using the DSMX satellites, I am only plugging 3 servo connectors to the SK-720 and my wiring looks much neater. I am still using the TM1000, but cannot receive antennae health in real time. However, I can follow antennae health post flight via the Skookum Playback logs. I sold all three AR8000's on eBay, and I am glad I did.
Whiplash E--ICE2HV160/KDE-495/MKS HV's, Synergy E5/S--ICE2HV120/KDE-530/Futaba HV's
T-Rex 600Pro XT--ICE2HV120/KDE-530, T-Rex 550--ICE100/KDE-1175, B130X, mCPx
VBar Silverline x4, Lots of KDE, DX8, Sims: Aerofly5.7 /RF6.5/Phoenix 4
johnahamelv is online now        Reply With Quote
Old 06-18-2012, 09:03 PM   #8
Airscrew
Thanks for the great info ! ! !
Old 06-18-2012, 09:22 PM   #9
chopstic
+1 nothing else needed
john powers lcdr
chopstic is offline        Reply With Quote
Old 06-19-2012, 01:02 AM   #10
Luvmyhelis
Yes, same here. Two sats directly linked to the Sk720 and running with my Dx7. Out well past 1/2 a mile a few times and no signal loss. Even with the cheapie HK orange sats!
Luvmyhelis is offline        Reply With Quote
