Go Back   HeliFreak > R/C Helicopter Support > 600 Class Electric Helicopters > 600 PRO Class Electric Helicopters
600 PRO Class Electric Helicopters 600 PRO Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 06-17-2012, 07:41 AM   #1
WBFAir
Default Source for 14, 15, 16T slant gear Pinons in M0.8
Hello all
Sorry if this is a discussed to death topic already but was looking for a source for slant pinons gears in the 14, 15, 16T for the 600EFL.
Guess this means .6mm shaft and a big thing if it needs it which I think it does, being M0.8 mod?
Thanks for any help.
WBFAir is offline        Reply With Quote
Old 06-17-2012, 11:55 AM   #2
WBFAir
Hey guys, please totally disregard my post above.
Made it in a bit of hast and before I found out that Align sold slanted gears in these numbers.
Also think I was wrong in that the main gear is a M0.6 not M0.8
Guess the Auto rotation is M0.8 which threw me off.
Am assuming though the main is M0.6 as the slanted pinion gears are that?
Anyway, those Align pinions should allow us to get the right head speeds with the Kontroniks ESC all with staying with the slanted CNC mains.
Old 06-17-2012, 12:47 PM   #3
WBFAir
ooohff.
Well guess I was wrong again, and am probably getting annoying at this point but it looks like what I was looking at was some pinions for the 650L motor which were slanted, and via being that the 650L motor is for 6S, essentially are not applicable.
So long story short, 600 EFL main gear is a M1 unless I'm wrong again, and so is any slant gear that would be needed I suppose.
Well guess this is probably been discussed so will have to go back through the threads.
Barring that perhaps will make a post looking for M1 Slant pinons gears in these size (thats a hint for anyone who might already know btw)
Anyway, my apologies for not being more thorough.
Old 06-17-2012, 02:10 PM   #4
NRPY
The 600 Pro main gear is indeed Mod 1. I thought someone sourced aftermarket Mod 1 slant pinions in the past, but I can't remember the details. Curtis Youngblood, maybe?
NRPY is offline        Reply With Quote
Old 06-17-2012, 08:04 PM   #5
martin_
Here you go for M1.0 6mm slant pinion, available from 10T to 15T : http://www.infinity-hobby.com/main/a...5ed604a1382a2a
Better to go with something around 550kv motor for higher head speed.
GeniusCP, main/tail brushless, V120D02S,
450pro 6S MSH Brain. 600pro SK-720. T-rex 700dfc SK-720.
800 Gasser into construction.
martin_ is offline        Reply With Quote
Old 06-17-2012, 08:24 PM   #6
WBFAir
I think I read somewhere that those ones at Infinity are not actually tall enough for the Align 600 gear?
I know they say its for it, but still.
Anyone herd the same?
