| Blade 450X Blade 450X Helicopters Information and Help |
I'm not overly sure about this step. What exactly am I looking for? Should the swash stay pointed to the front of the heli or stay pointed at at fixed location, i.e. the kitchen door or something like that? (When you hold the rotor and spin the heli) Mine doesn't seem to do either and the setting I have assumed is correct is actually the reverse one, according to the setup light.
Also, if the pitch and aileron servos were swapped, would this affect the setup? I bought my heli without the controller, the plugs were all marked, but I now suspect these may have been marked incorrectly. |
Upon entering Setup Menu N, the swash is purposely tilted.......As you piro your heli, the tilted swash should remain in the same plane as you piro.
Search YouTube for "mguw"......Marcel's 4-part video tutorial on the BeastX is excellent and will explain this clearly.... In fact, I believe that viewing this vieo tutorial should be mandatory for anyone using a BeastX or AR7200BX.... FWIW |
should stay pointed in the same direction. Purpose is to keep the heli tracking in the same direction during piro
Stop making excuses and fly the damn thing! B130X (x2) B450X (x2) T-Rex 550E, 700E, Goblin 500, 700 Habu 32, Extreme Edge 540T, various foam junk |
Gonna be a super cheap 450 x up on the for sale board here soon - or on the bottom of the estuary down the road from here! Tried to get a hover out of it again today, not a chance, not even close. I can hover my $79.00 HK 450 at least, but this thing won't even lift the skids without tipping, tilting, sliding, etc. Tipped it over eventually, I think th cut saved the drivetrain, although I'm not sure all the servos are healthy now.
Ran through the Beast X setup again, now I can't get the swashplate to move in the right direction for collective unless I reverse the aileron and pitch servo directions. Then the aileron control gets reversed. Seriously, for an expensive helicopter that gets rave reviews, I'm starting to think mine is just a POS ![]() |
AD, did you youtube mguw's videos?....
Setup Menu I is where you adjust servo reversing, first. I went through the same thing as you're going through...... ![]() Finally, I just simply did the "factory" reset.....enter any Setup Menu(A thru N) and then press the button for 10 sec.............you'll know...all the LEDs blink and so forth..... Power down....and then go through the whole setup procedure...... And remember, for I have made this mistake, don't twiddle the cyclics in Parameter Menu A...Param. A is a blinking status LED........If you move the cyclics, you are adding "trim"....and when you exit this menu, you cannot come back to factory status.....unless you reset.....I screwed myself on this and had to reset......it works...lol Just set your Tx settings to the manual specs...........take a deep breath.....and just do an AR7200BX factory reset as described above........ What I did was to have my laptop by my workbench.....so as I was doing each step, I could halt the video as necessary at each step of the Setup Menu A thru N..... AR7200BX factory reset is highly recommended at this point, AD.......FWIW |
#6 |
I found a tutorial on youtube for setting micro beast, but haven't found part 1 yet. The frustrating part is I was happy with running through the beast x settings until today! Anyway, I'll search when I get home. Had to leave it for a while to stop me living up to my username
#7 |
Also make sure you have not got the pitch servo lead and Aileron mixed up at the Ar7200BX, Dont ask how i know... but lets say it makes for a very short flight.
One of my first mistakes after an early rebuild. ![]()
MCPX V2 Tarot 450 pro V2 FBL Zyx gyro Blade 450X FBL retired to the black bin bag!! To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#8 |
That's one of the things I thought was wrong. I unplugged both of them and then tried one by one. That's where my troubles started! Aileron is the right hand side, looking from the tail rotor end, and pitch on the left?
#9 | |
Don't get in a rush...take your time.....and viola! In time, you will be an AR7200BX expert....... FWIW |
#10 |
OK, I got it all working again, I swapped the aileron and aux1 plugs on the beast x and went through it again, servos are now all in normal, swash moves downwards (Correctly) for collective and aileron control works correctly. I even got the correct purple light (Default factory setting), for mix control, which I could never get before. All seems good, but now I'm confused. Again! Now if I unplug the aux 1 plug the right (STBD) side servo stops working. If I disconnect the AIL plug the left (PORT) side stops working. Isn't this now back to front? Or doesn't it matter?
Also, I thought my elevator servo was notchy, just took it apart and checked it, found nothing. I will try another hover as soon as I can get the nerve - nerves are shot to bits now! So much for my "Nice relaxing day off tinkering with and flying my helos" ![]() Is this the series you are referring to? |
#11 |
Nice job!
Take your time...what's the rush?..... Your success is our desire...... FWIW |
#12 | |
#13 | |
#14 | |
Still having a hard time even hovering this thing, gave up and took my TREX clone out instead. Still tricky, but far easier than this one ![]() |
#15 | |
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. 12S Gaui X5 Formula, Scorpion 4035-500, AR7200BX, 6S Gaui X5 FES, AR7200BX, 6S Blade 450X w Scorpion 2221-2010, CC Ice Lite 50, 14T, MKS DS92A+, MKS DS95i, 1300mah (835 gm RTF, 595 watts, 3650rpm) |
#16 | |
However the factory setup 450x is very very responsive compared to the HK450. You can tone the 450x down till you find your comfort point. Ether TX mode using DR/EXPO or on the BeastX using sport mode (warning: change only one...but not both). Hang in there, and you will love 450x... the HK450 will be gathering dust.
Takeoff is optional, landing is mandatory. Blade MSR, MSRx, MCPX*4, B450x+HC3SX, Protos 500 stretched+Brain, Century E640+HC3SX |
#17 | |
I've been using the 450 clones (Actually got 2 of them) as training pigs, figuring I'd prefer to trash them than the 450 x. I'm already down to 1 now lol I think my 450 x needs all 3 cyclic servos regearing - they're all notchy, compared to the rudder one Last edited by Angrydad; 06-19-2012 at 02:11 AM.. |
#18 | |
IMHO, the stock servos are trouble waiting to happen. I have switched to h3000 on the mains, and have a ds95i tail on order.
#19 |
Wait a sec. Are you tuning the radio and setting the "flight mode" to sport? IIRC the manual says to leave everything (throw/DR/Expo) at 100% and simply select the desired flight mode in the BX? Not both. I set mine to "transmitter" and tune from there. This worked flawless when I transitioned my #2 7200 from the parts kit to a Rex Sport v3. I did the factory reset and went A-N to the letter.
Also, are you popping it off the ground or what? My 3G units were a bit more mellow about spooling near liftoff, BX not so much. |
