| Mikado Logo Helicopters Mikado Logo Helicopters Discussion |
Ok guys... The maiden of my friends L600SE that I built and programmed went great!
I just need to make a few adjustments. When pirouetting at full stick both left and right, letting go of the rudder results in an overshoot of the tail. How do I get the tail to stop on a dime (or at least more abruptly)? It overshoots both ways but tail going to the right is worse. I actually can't think of any other adjustment needed right now. I'm sure I will after the next flying session though. Two thumbs up for the SE and my first time setting up V-Bar myself.
Logo 690SE V-Bar /// Logo 560 V-Bar /// E325 mini-Titan /// Blade 130X /// Blade mCP X /// Blade nano
"Ginger" 11/10/02--7/6/12 Last edited by 3D Dave; 06-21-2012 at 08:42 PM.. |
Congrats for the maiden! Love the SE too.
You might have a look here is something could work out for you: http://www.helifreak.com/showthread.php?t=297657 Chris
Logo 600 3D MiniV 5.3 Pro SAB Goblin 500 MiniV 5.3 Pro Rigid 480 6S Beast X MCPX BLS |
Lower the stop gain a couple points on both sides in the tail expert menu and try again. Stop A is for CW piros and Stop B is for CCW piros.
Steve To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. #1 - Logo 600SX-THOR 10s 4400, YGE 90HV, Scorpion 4035-560kv on 12T pinion, BLS451/251 #2 - Logo 700-THOR 12s 5000, YGE 160HV VBar Gov, Scorp. 4525-520kv, BLS451/256 |
Thanks. I did that and will hopefully get some more flights on Thu. to test.
"Ginger" 11/10/02--7/6/12 |
Steve,
Lowering the stop gain didn't cure the overshooting of the tail. I tried (was 20), 18 (seemed a little worse) and then 16 (to make sure it was worse). Then I tried raising it (22, 24, 25) that didn't really help it either. I even tried raising the regular tail gain. That didn't help. Holding full left rudder and then letting the stick go (back to center) results in the tail overshooting 18-30 inches beyond where it should have stopped. Holding full right rudder the heli starts the pirouette slowly, then speeds up but the stop (stick let go to center) still overshoots about 6-12 inches. Giving the collective a little blip/punchout also causes the tail to rotate to the right about 8-12 inches or more. I should probably ask this in the V-Bar forum now. Any other ideas? I must be missing something. ps I have absolutely NO wag. The tail is rock solid in a hover.
#6 |
What headspeed? :-)
(´・ω・`) ギルティクラウン (´・ω・`) (´・ω・`) (´・ω・`) |
#7 |
What headspeed? :-)
PS Is the tail very noisy during stops?
#8 |
Well I was there, and since you may be on different schedules- the tail wasnt making noise nor wagging, just overshooting. The tail gain was at 90 which is high for my outrage 550.
#9 |
Blink, the HS "should" be 1663 according to MrMel's HS calc.
Throttle 60%: 1663 Throttle 65%: 1715 Throttle 70%: 1767 Throttle 75%: 1819 Throttle 80%: 1871 Xera 4035/3y-400kv, 35c 12s batt, 12t pinion, Jive mode 4, Edge 105's & 690's And as Jon mentioned, no noise on the tail at all. I'll have to tach it next time out to verify.
#10 |
Well this is quite strange and I havent much to say about this. I had slow wag issues in a hover that no gain or setting could adjust on my 600 3D, So i simply just ignored it and did a 4:35 minute 3D flight, next flight it was fine.
Silly idea but perhaps just fly it and hope for the best until you get proper help from mr mel? :-) Also, try drastic tail settings, high stop gains, high p gain, high i gain, higher acceleration numbers, ignore tail wag as long is its not very bad and see if the stops are better. PS what tail servo are you using?
(´・ω・`) ギルティクラウン (´・ω・`) (´・ω・`) (´・ω・`) Last edited by Blink 182; 06-22-2012 at 08:48 PM.. |
#11 |
I had same thing. Tail bellcrank was cracked. Check yours.
1 - LOGO 600 stuffed with angry hornets 2 - A sad & lonely looking Rush 750 that I can't find time to finish. 3 - 7HV stuffed with over-tired honey badgers |
#12 |
Blink, the tail is a brand new BLS251.
I am going to try some suggested settings from Fredrik. Slider gain 85 60 Acceleration 75 P gain 75 I gain Pre comp (we'll probably have to raise collective a bit) 10 collective 3 cyclic Stop 20 A 20 B @ OT, I checked the tail bellcrank. Looks ok. If all goes well Tue, I'll be continuing MY 600SE build.
#13 |
Just a quick update...
My buddies 600SE is flying great! Went with: Slider gain 95 75 Acceleration 75 P gain 75 I gain Pre comp 15 collective 3 cyclic Stop 25 A 25 B We'll be doing a few more flights with the optimizers ON and then see how she is. Thanks again for the help!
