Go Back   HeliFreak > R/C Electronics Support > YGE
YGE YGE ESC Support and Discussion
Old 06-19-2012, 03:02 AM   #1
HSC
Default YGE setings normal throtle curve
Hello !
- Because I have tail problems with my heli I have disabled governer on my birdy and I activated normal trotle curve 100,80,100 ( idel 2 ) add some ciclic mixer in throtle ( 10%), governer is werry "tricky" with small helis even Mini Jazz do not work perfect....
Soo lets goo to the problem:
I leave softstart at heli midle.
Softstart seems too be OK, but reaction of motor during flight is too soft and delayed, the heli flies sooooo funy " puding stiyle",but................ the tail problems are gone.
What I em missing hear, how should I setit the YGE 30 too get softstart at first exceleration, and right reactions in flight?
If I set to exseleration to "plane fast" reactions are good, but I lose soft start, wich is not OK at all....
Thanx for help
Regads
A je to ?
HSC is offline        Reply With Quote
Old 06-19-2012, 11:29 AM   #2
HSC
Well it is mee again, I have try ewery posible way and I can not set this, grrrrrrrr
I just do not belive this controner do not have this function.
A je to ?
Old 06-19-2012, 01:04 PM   #3
urgno
usually what give tail kick problems is active freewheel enabled ... try to disable it ;-)
my Prtos twins & Acrobat Shark
urgno is offline        Reply With Quote
Old 06-19-2012, 05:05 PM   #4
Steve Evans
Describe the tail "problem"...
Steve
Trex 450SEv2/HS65-MGs cyclic/Spartan Quark/DS520 tail
Trex 450ProV2 DFC/CGY750 FBL/DS410s cyclic/DS520 tail
Trex 500ESP DFC/CGY750 FBL/YGE-120LV ESC/DS510s cyclic/DS650 tail
Blackout 330/OpenPilot Revo with FatShark 600mW VTX, Futaba 8FG 2.4GHz
Steve Evans is offline        Reply With Quote
Old 06-20-2012, 12:42 AM   #5
HSC
Hello !
Could bee freewhell, will try out lately today or tomorow.
"Describe tail problem"
1 case : Hard flip on the clockwise direction 180 deg, short input on roll for 1/4sec ( if you look heli from back), tail lose hold and change direction for 90 deg, werry anoying....
2case : Slapper, same problem in the point of turning 180 deg on roll ( top of the slapper )
Describing manever : Start with usual rainbow, when heli reach top position ( tail to the ground ) in that point you need too putt pich to zero and make 180 deg on roll and after that you continiue with rainbow turned back forward....
It seems like when change torque from 100 % to 0 and then again 100% problem become visual and werry dangerous if you fly few meters from glound...
All this problems are gone with normal pich curve ( 100,93,80,93,100 ), yesterday I try in plane mode ( fast ), works perfect, only softstart sucks totaly...........
A je to ?
Old 06-20-2012, 04:10 PM   #6
Steve Evans
Have you tried playing around with the ESC PWM, P-gain and I-gain when using gov-store? This has a significant effect on the RPM overshoot when coming off load and this could be the cause of your tail issues. Check out THIS thread for more details.
Steve
Old 06-21-2012, 01:20 AM   #7
HSC
Hello !
Well yesterday I was testing with freewheel OFF and heli fly now almost perfect........like in fairytale
the same like with normal trotle curve, ewen better in a lot of cases.............
No doubt reason for my "kicks" was freewhile enabled, even governer runs a lott smoother...
Soo boys I must thank you for advices and for the help, also werry useful link from Steve, thanx
Regards
A je to ?
Old 06-21-2012, 10:13 AM   #8
urgno
very good ... glad to help :-)
