Go Back   HeliFreak > R/C Helicopter Support > Beam
Beam Beam Helicopters Factory Support Forum
Old 06-19-2012, 07:17 PM   #1
Carthagenj
Default Best Batteries for Beam E4 V2 Advance
I searched this forum but did not find any current references. So let me pose the question: what batteries would you recommend for an E4 V2 Advance with ICE 50 and Scorpion 2221-8 with 14T pinion?
Carthagenj is offline        Reply With Quote
Old 06-19-2012, 10:19 PM   #2
dpelletier
I use Gens Ace and Sky Lipos - 3s 2200mah
Futaba 14SG, Synergy E5, Furion 6, Beam E4(v1) FBL, CGY750, Skookum
dpelletier is offline        Reply With Quote
Old 06-20-2012, 12:13 AM   #3
Carthagenj
Dany,
What discharge rate are they?
Mark
Old 06-20-2012, 06:14 AM   #4
olemil
Not sure how the V2 compares to the old V1 version, but I have three of these and two of these. I had to go with a heavier pack to get my CG right since my ESC is mounted rearward of the main shaft. I like the Venom packs the best but of course they are a bit more pricey. I cut off the uni-connector on the Venoms also and installed XT-60's. I get 5 minutes of flight time running a 2221-6 motor with 11T pinion, but I don't fly that hard either.....lol.
Beam E4-(Scorpion HK-2221-6,11T pinion, Phoenix 60, HS65MG cyclics, GY520),120SR, Trex 250SE (stock) MH bottom plate,GY-520,Futaba R6106, MCPx,DX7se,Futaba 8FG Super, HPI Vorza on Futaba 4PL.Honda HS928K1TA
olemil is offline        Reply With Quote
Old 06-29-2012, 01:54 PM   #5
Bluerocktj
I've heard nothing but good things about Gens Ace. I'll most likely pick up a few later. I'm currently running Hyperions G3-VX2200-3S, they've never let me down. After over 100 cycles, these packs are still solid!
Beam - "Best Expert Acquired Man" - "Beautifully Engineered Action Machine"
Bluerocktj is offline        Reply With Quote
