Old 06-21-2012, 09:50 AM   #1
Jotto
Default Where to get new slant auto gear and counterbearings
Are the new slant auto gears and counterbearings available anywhere yet? I can't find them on helidirect, at least.
Jotto is online now        Reply With Quote
Old 06-21-2012, 11:15 AM   #2
Goodlett
I ordered from China. Infinity Hobby shipping is quick to the US.
Goodlett is offline        Reply With Quote
Old 06-21-2012, 11:44 AM   #3
ualdrivr
Is that what you're looking for?
http://grandrc.com/p51745/H70110-700...duct_info.html
Can't seem to find the H70111 motor pinion gear mount.
http://www.align.com.tw/shop/product...23&language=en
At the precipice, we change!
Team GrandRC
ualdrivr is offline        Reply With Quote
Old 06-21-2012, 12:08 PM   #4
Jotto
Yep, that's the one, thanks!
Actually helidirect has the pinion support, but not the slant gear: http://helidirect.com/align-700e-mot...11-p-26776.hdx
Old 06-21-2012, 02:38 PM   #5
ualdrivr
There you go, all set!
Team GrandRC
Old 06-21-2012, 07:19 PM   #6
OnTheSnap
It took me me 2m with a dremel to hack the stock counter bearing. Save some cash and hack it.
Goblin 700, Goblin 500, Synergy E5-600, Fusion50, Rush7
HeliDirect, Team iKon, GrandRC
OnTheSnap is online now        Reply With Quote
Old 06-22-2012, 01:46 AM   #7
JustinS
Don't be so tight, buy the Align one that suits kidding
Bit hard to track down at the moment, I bought the 2 parts from infinity & heli direct.
JustinS is offline        Reply With Quote
Old 06-22-2012, 10:32 AM   #8
terrabit
Any word on whether the KDE adjustable mount fits without modification?
terrabit is offline        Reply With Quote
Old 06-25-2012, 10:38 PM   #9
OnTheSnap
I heard it does not fit. Counter bearing can't be hacked far enough.
Old 06-26-2012, 02:46 AM   #10
terrabit
Wouldn't it depend on the pinon? A larger pinion would move the adjustable mount away from the main/auto gear. I'm currentlyrunning a 13t. Whatever, epic fail Align! Hey Align, here's a crazy idea ... make an adjustable motor mount.
Old 06-26-2012, 08:12 PM   #11
Mikey D
I just installed the new auto slant with kde motor mount and kde counter bearing. Im using 13t pinion and it will fit with no modifications. It is very tight almost to tight, but it does not rub.
FWIW..li am running 750mx with 13t pinion at 2250 head speed and the new autorotation gear with stock tail blades and DFC head.
This setup is freaking off the charts!. Kudos to Align for these updates!
Mikey D is offline        Reply With Quote
Old 06-26-2012, 08:13 PM   #12
OnTheSnap
So the 13T adds enough space then between the counter bearing and the gear. Great!
Curious, you found it necessary to go to a 13T with the 750MX? My 750MX is bogging quite a bit at 2200 and I suspect it is lower than 530kV. I'm interested in hearing your experience there.
Old 06-26-2012, 08:15 PM   #13
OnTheSnap
Yes, I _really_ don't understand why Align offers 3 different kV motors instead of multiple pinion options with an adjustable mount.
Old 06-27-2012, 12:38 PM   #14
Mikey D
OnTheSnap
I have no bogging what so ever with the 750mx. I tried the 12t pinion, but did not go past 2100 on the headspeed. Probably could have in retrospect.
I just ran the numbers through Mr Mels head calculator and it made sense for the 13t with my desired headspeed (2250).
I use the stock Castle 120 v3.27 with a 70% curve to give me 2250 HS.
Hope this helps
Old 06-27-2012, 12:52 PM   #15
badfrog
another source
http://www.readyheli.com/H70021B-CNC...B_p_39357.html
AMA# 977810
badfrog is offline        Reply With Quote
Old 06-27-2012, 01:13 PM   #16
Mikey D
Isnt that the main gear? You can get the auto rotation gear at GrandRC last I looked.
Old 06-27-2012, 01:17 PM   #17
badfrog
Sorry... you are correct! they also have the slant gear. It appears that you will also need the H70111 bearing block as well...
AMA# 977810
Old 06-27-2012, 01:55 PM   #18
terrabit
That should have been addressed in the first revision, the v2 model. On to v3 and still no OEM solution. Baffles me.
Old 06-27-2012, 05:37 PM   #19
OnTheSnap
Old 06-27-2012, 06:13 PM   #20
brian94066
I don't use a counter bearing, so i'm good to go
Amainhobbies.com
Protek R/C
Cyclone Blades
Scorpion Power Systems
brian94066 is offline        Reply With Quote
