| mCP X Blade Micro CPx Helicopters Information and Help |
I want to download some custom firmware into the MCPX
3 in 1, which means, write your own FBL control to have adjustable tail gain etc. I have make enough progress understanding how to talk to the receiver chip. See here: http://www.helifreak.com/showthread.php?t=427772 I also make a PDI plug to download the firmware into the atxmega16a4 on the 3 in 1. I can read the device fuse and lock bits fine. I believe I just need to click "erase device" and then I will be able to down my own firmware to the 3 in 1. The catch is that, I will never able to get the original firmware back. But it seems such a waste to destory a perfectly working 3 in 1. Here is where I am asking for help. Does any one has some really broken 3 in 1 board they don't want so I can buy it cheap? I do mean really broken. Things like board do not bind is fine by me because I can still use the MCU to do some programing with the gyro etc. I can even pull the receiver signal from the good board. I also perfer the V2 board because V1 board are good for BL conversion, even broken one has some value to some of us. If you have a really broken V1 board, I might able to fix it up for you. Note: Burning FETs are easy fixable by a few members here. PM me if you have some broken 3 in 1. Thanks |
Can't you just read the device and save it as a backup, or is it copy protected?
You can always remove the AVR and replace it with a blank one |
My buddy has a board that broke the corner of the pcb.
cp11:
As I post on the receiver chip thread, the MCU on 3 in 1 has the lock bit set to disable all read/write. The only way to download firmware is to erase the device. It is design to protect the original firmware. I can replace with a blink one, I even bought a few and clean up the conforming coating on one of my board. But Still it is a lot of work to take the MCU out and put a new one back on. Using a broken 3 in 1 is much simpler. Drivnfast247: Thank you. Will send you PM. |
How many do you want? I think I might have a few.
Sent using Tapatalk. Please forgive/ignore autocorrect errors. |
#6 |
Thanks Mega, that is great. If a board is consider broken by you,
it is definitely broken enough for me that I don't feel guilty flashing it. If possible, I would like to get a few to cover different board revision. Thanks again. |
#7 |
Too bad about the code protection, but it's expected I guess. Are you writing it in assembly, or C? You should find a tiny speaker and program it to play songs or a siren while you fly!
#8 |
HH will definitely use a MCU that protects their firmware. It is expected.
I am glad it is not like the avr mega series which I need to solder 20 pins to just erase it. Done that for the walkera ESC. I will be writing in C and thinking in assembly code that C generates. I have update some guess about the MCPX debug port in the receiver thread: http://helifreak.com/showthread.php?t=427772&page=3 |
#9 |
Here are some notes on mapping the V2 MCU pin out:
I use the port number rather than chip pin number. You need read the datasheet to map them back to chip pin number. The port number is easier for programming. portA: [0:2] not used. In V1 it is the gyro analog input. 3: motor ground plug. OCP input. 4: monitor battery Vcc/2 5: main motor output voltage measure 6: tail motor output voltage measure 7: MCU voltage monitor (3v /2) Port B: 0: connect to porta_7, MCU voltage. [1:3] Not used Port C 0: I2c data for gyro 1: i2c clock for gyro 2: Debug port serial out 3: Debug port serial in 4: tail motor pwm 5: main motor pwm 6: LED, push to light it. 7: not used. port D: 0: Right servo PPM 1: Elervation servo PPM 2: Left servo PPM 3: Not used 4: Receiver data interrupt. 5: Receiver data SPI data 6: Gyro Interrupt (That is the line has receiver data plumb into it) 7: Receiver SPI clock Port E: not used. |
