| mSR X Blade Micro SRX Helicopters Information and Help |
Hi guys, i was hoping someone could help me out, as i have purchased a new MSR X flybarless fixed pitch chopper.
Im reasonably new at flying choppers but have been practicing on my G5 sim to get my head around it and am pretty confident in my ability to fly this puppy. I have been flying on and off fixed wing for many years. Im using a new Spektrum DX6i as my controller and am not sure of the settings i should be using for this micro chopper ?? I have put a battery in it to give it a try as you do when you buy something new and are desperate to have a fly, lol, but I think it has a problem as when i throttle up the Aileron servo extends itself without any input by me. Ive tried to trim this out but to no avail. I have bound the Heli ok, that part is all good. But I found that when i throttle up i can see the Aileron servo slowly moves up to its highest possition and this obviously wants to make the chopper bank to that side. It corrects itself only, when you throttle back down again and the servo goes back to the neutral possition. Does anyone have any ideas for me please as i dont know enough about this Heli, or does this sound like a problem with the Heli itself, and needs to be taken back ??. I havent even flown it yet, so it hasnt hit anything, i have just taken it out of the box and wanted to hover the thing the best i could in the one spot, but haven't been able to do that cause of this problem. Thank you in advance ![]() |
Hi everyone, Ive been enjoying reading the posts and forums on your site with all your knowledgeable people in regards to various problems people have.
I live down under in Sydney, Australia , and our weather has not been real good for flying outside, cause its either raining or blowing a gail or both together at the moment. It seems that I'm always working on the good weather days and cant get a fly in. Lol. Thats what it has been like for a while for me anyway, it just seems to never work out for me lol. Hence the urge to get a little indoor/outdoor chopper to fly to get my fix. Lol. After all its like electronic cocaine my addiction of flying, lol. I have bought a new MSR X flybarless fixed pitch chopper and have a slight problem with it, and was wondering if anyone could help or if it was just me doing something wrong with the settings on my DX6i. I'm thinking there is a problem with this new Heli i have purchased. I have just got it out of the box and started to try to fly it, but have noticed that as i throttle up the aileron servo also moves for some reason and causes the chopper to veer to the left quite significantly. I haven't given it any input for it to do this, and it is really driving me nuts. I have tried to trim it out but this did nothing as it just seems to automatically do it when i throttle up, but when i throttle off it self adjusts back to normal and centres its self again. It doesn't seem to matter what i do it doesn't work, arrr. Has anyone heard if this is a problem with these new helis or am i doing something wrong ?? ![]() Thank you in advance Chris |
Search on this form for the MM mod..........this'll take care of most, if not all of the kicking over to the left.......welcome aboard!
I own two of these things (one converted to brushless), they're a lot of fun.....
/MSRX, MCPX, Nano, 1SQ, several 130x, Gaui X2, 300x, 450x, DX8, Harley Road King To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. "It's not getting any smarter out there, you have to come to grips with stupidity and make it work for you" - Frank Zappa |
If you're holding it stationary and throttling up the servos will move like that (I'm guessing it's the as3x adjusting the servos). Pop off the aileron servo pushrod and turn it(the black part that connects to the swash plate)icounter clockwise 3 full rotations (loosening/lengthening it). Pop off the elevator push rod and twist that one (the black part that connects to the swash plate) clockwise 1 full rotation, tightening/shortening it. (the aforementioned mmm mod). If you don't turn them a complete 360 degrees you will be trying to force them onto the swash plate and break something. They only go on 1 direction. Hope this helps. I know it did for me
This will make it much more stable in a hover. |
Oh, and don't trim it with the remote. It messes it up. Keep your trims at center when doing the mmm
#6 |
agreed, the only time i ever use trim, even on my msr, is rudder (<4 clicks), when I have a tail motor on the way out.....
#7 |
Thanks for the info Koi-fish and Ecnalab, im working today but will have a look tonight to reign in this new MSR X of mine. Thanks again guys
Chris |
#8 |
Also, when you attach the battery, leave the heli on a flat surface for a few seconds as the gyro learns level. Else it will not fly right.
As said before, keep all trims centered.
Syma S107, Nine Eagles Bravo SX 320A Blade mSR X, mCP X v2, MQX, Nano CP X Blade 450 X, DX6i, DX8, Phoenix V4 |
#9 |
I found mine did this also out of the box. What i found works well is throttle up until its nearly light on the skids to get the head speed up. Then Give it a fair bit more so it sort of pops up into the air. I found if i do a slow take off it veers to the left. A fast pop in the air and most of this left motion is taken out.
hope it helps. ![]() |
#10 | |
#11 |
Definitely don't give it any trim -- that disables the stabilization system and it will be really twitchy.
#12 |
I think im being a bit too precious with it, lol. Grab the bull by the horns you reckon and just try and fly it like you stole it, lol. I was going to try and take it back to the shop but im going to give it a crack and see what happens, hopefully not literally.
Thanks heaps for the info guys. |
#13 |
I love this thing, its great fun. Chris |
#14 | |
#15 | |
#16 |
Cool keep going mate. I'm such a noob and loving this thing. Can now Forward Fly. This thing is awesome. Had some big stacks but no damage yet
#17 | |
Cheers Chris |
#18 | |
This week, when I get the parts in the next couple of days, gonna add a bigger brushless motor and a brushless tail....ride it like you stole it, indeed. I have a mild stocker as well with some rakon bling
