Old 06-26-2012, 01:25 PM   #1
zorax2
Default Do cyclic servos need to be replaced as a matched set?
For example, if one Align DS-410 servo goes bad, can I substitute another brand's servo in its place or am I forced to replace it with another DS-410?
Fusion 50 - 6S, CC100, SK720, Trex 450 Pro - SK720, E-flite MCPx & MSRx, Spektrum DX8
zorax2 is offline        Reply With Quote
Old 06-26-2012, 01:28 PM   #2
rhodesengr
all three need to be the same with the same arm length. The tail servo may be different.
This is your brain on helicopters!
Trex 700L, Trex 700N DFC HB gasser,Trex 700N V2 HB gasser, Trex 550E FBL all with BD3SX
rhodesengr is offline        Reply With Quote
Old 06-26-2012, 01:34 PM   #3
Starcruiser
I would replace cyclic servo's with the same brand and model since all servo's are not necessarily the same, i.e. the response and travel may vary thus causing issues with symmetrical travel.
Carl
Trex 550E FS Vbar Pro 5.2- EXI-450T Mini Vbar Pro 5.2 - EXI 450T BeastX - Trex 250SE - mCPx v1 Hp05 & HP06 w/HP03t tails - AMA #952544
Starcruiser is offline        Reply With Quote
Old 06-26-2012, 01:45 PM   #4
Corvette & Copter Guy
Are the gears stripped in one of your servo's or did it just die? I take it the servo is for your 450. An option is the Power HD servo (HD-2216HB). I run these on my 450 and for the price and function you cant go wrong. $28.00 for an align, or $12.00 for the Power HD. If I remember right, if you buy four of them they are $11.00 each.
LOGO: 480XX, 550SX, 600, 700, 800XX, 230s NIGHT, HISKY HCP100
VCONTROL, NEO, TRIBUNUS, DPL8, BUMP CONTROL, MEANWELL
Corvette & Copter Guy is online now        Reply With Quote
Old 06-26-2012, 09:42 PM   #5
mediclavina
Unless your heli swash has 1-servo layout (like the Bergen helis), always use the same specific servo for all the CCPM servos.
GAUI EP-200 V2 FBL, Blade Nano CPX, Blade mCP-X, Hirobo SRB Quark, Blade mSR, Blade mCX
mediclavina is offline        Reply With Quote
Old 06-27-2012, 01:44 AM   #6
Sabaot
It is highly advised (some even say - mandatory) to have all cyclic servos from same manufacturer and same type. The reason is speed and force. For example purposes let's take typical T-Rex 450 swash 120* setup. Let's say you have KIT servos. One goes dead and you replace it with other brand. Your original servos have turn rate at 0.14 sec while your new one is 0.11 sec.
Now you go out flying and do some simple but fast maneuvers (I'm not into 3D so don't know the names - the one when you "jump" with heli up and down). This maneuver requires all 3 servos to work together and equal to give you desired figure. With one servo out of the set you won't achieve that. Depending on where that servo sits you will get a slight lean in a direction under that servo control.
So if it's ELE servo you'll have a slight lean toward when ascending and slight lean backward when descending as that servo is stronger and faster that other two.
CopterX 450 SE v2 | "Gekko"
Sabaot is offline        Reply With Quote
Old 06-27-2012, 02:51 AM   #7
Lee Taylor
Just replace the bad one with a good one of the same type. Otherwise, yes...replace all 3. For cyclics, the set needs to be of the same type (model).
CYJE - Field Rep
Ballistic 700/520 Ultimate/CC 160/Radix V2
ENV 105/MP7/Radix V2
Lee Taylor is offline        Reply With Quote
Old 06-27-2012, 03:13 AM   #8
kavic5150
Post
+1 for what Lee Taylor said.
Hit throttle hold and raise/lower your throttle stick to see if your cyclic servos are traveling smoothly and evenly. Also you can carefully move each servo arm to feel for any notchiness or skips.
kavic5150 is offline        Reply With Quote
