Go Back   HeliFreak > R/C Helicopter Support > Compass Model Helicopters > Atom 6HV, 6HVU and 550 Ultimate
Atom 6HV, 6HVU and 550 Ultimate Compass Atom 6HV, 6HVU and 550 Ultimate Model Helicopter Discussion
Old 06-27-2012, 10:14 AM   #1
TBur
Question Heli is talking to me, what is it saying ?
getting a strange chirping sorta sound. you can hear it when the heli is close in this video.
when spooled up on the ground it does not make the noise, only after lift off.
its new - < 12 filghts. (for other issues the motor and tophat bearing replaced, most of tail as well - except the slider bearing)
Its been consistent, have not noticed any particular control inputs that change the noise.
Any thoughts on where to start looking to track this down ?
Thanks - Tim
7HV NEO 700XF
Goblin 630 NEO 600XF
Agile 5.5 NEO
Vcontrol
TBur is offline        Reply With Quote
Old 06-27-2012, 06:13 PM   #2
snaaakeey
Not too sure if it's the noise your on about but the short group of high pitched pulsing sounds the motor made sounds possibly like too high a gov gain? If you rant running a gov then not too sure? My 6hv has gone through many strange noise changes in it life. Most haven't been a problem.
Sent from The Pad of I
6hv (fb)
7hv
DX8
snaaakeey is offline        Reply With Quote
Old 06-28-2012, 12:09 AM   #3
TBur
I am running the skookum gov, all settings for the gov are the defaults, I'll check into those settings. Thanks
7HV NEO 700XF
Agile 5.5 NEO
Vcontrol
Old 06-28-2012, 12:44 AM   #4
Grok
That noise can also be caused by a vibration.
Sent from my Galaxy Nexus using Tapatalk 2
Grok is offline        Reply With Quote
Old 06-28-2012, 03:36 AM   #5
360Wings
Sounds fine to me... Just fly..
Play around with the gov. setting.. Gov. setting vary alot depending on h/s, blades, motor torque ...etc... Im running a SK540 and i have the gov gain at 34.
360Wings is offline        Reply With Quote
Old 06-28-2012, 09:06 AM   #6
TBur
Was reading some posts, seems like low 30's is a good place to start. I'll give that a try tomorrow
7HV NEO 700XF
Agile 5.5 NEO
Vcontrol
Old 06-29-2012, 09:22 AM   #7
snaaakeey
I'm running the scorpion 4525le and the highest I can get on the sk720 gov is 29.
Edit. Sorry ! In the 7hv!
6hv (fb)
7hv
DX8
Old 06-29-2012, 10:21 AM   #8
alexmit
This could also be a PWM rate in the ESC that is too low. That can cause chirping under load. I'm not saying that is what it is for sure, but it could be.
SAB USA Factory Pilot/Field Rep. Pulse Battery USA Field Rep. BK Servo Team Pilot. Team Spartan USA. Canomod USA Field Rep.
alexmit is offline        Reply With Quote
Old 06-30-2012, 09:46 PM   #9
TBur
Running the hw 70 @ 15, tried 18 and 21 previously, didn't alter the noise, good suggestion though.
Traveling now. Won't get a chance to fly till the end of the week.
Regarding the SK gov gain, tried 30, had gusting winds making enough noise friday that I couldn't say for sure if it helped.
7HV NEO 700XF
Agile 5.5 NEO
Vcontrol
Old 07-15-2012, 09:02 AM   #10
TBur
I think it was the gov gain. I'm still in process of trying lower numbers, but the pulsing noise is much less now. I'll post what I end up with.
Taking a while, had a crash/ fix... Then road trip where I couldn't try it it till the 6th, then an auto reset at about 6 inches off the ground on re maiden.. I had no Internet access so was not aware of the 3.1 logging issue... Figured maybe the crash had damaged the bec so I ordered a new one and replaced it when I got home.
Was greeted back in Seattle with T storms Friday ;( , got a 3 minute flight in yesterday before it started raining. Argggggg.
Oh well now I have a spare bec...
Tim
7HV NEO 700XF
Agile 5.5 NEO
Vcontrol
Old 07-19-2012, 12:10 AM   #11
TBur
Ended up setting the gov gain to 27, no more pulsing noise
7HV NEO 700XF
Agile 5.5 NEO
Vcontrol
