| 450 PRO Class Electric Helicopters 450 PRO Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
I m loooking for some ideas on the best way to hold the ant. wires of a AR7200BX.
I am mounting in on the gyro platform so it is easy access. The wires need to be purpendicular to eachother. Was thinking of tywrap, but maybe someone has a better method. Pictures would be great. Thanks, Dan
Dan AMA# 987374 - T-rex (550DFC,550E, 500FB, 500FBL, 450-Sport, 450-Pro), Blade (400 Mcpx 120SR) - DX-7- And a ton of spare parts |
this is on my 500 but should work with the 450, i just drilled small hole and ziptied the ant
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
I like that...but that does not look like a 450-pro.
For some reason my gyro plate does not stick out past the base of the AR7200BX. I can't find a place to run the ty-wrap thru. I "might" drill a hole in the flange of the tail-boom support case for the ty-wrap. But I would like my wires to look like what you have. Dan
I put a extra eyelet on the boom and passed the longer ant through.
I also bought the tarrot anti rotation bracket FBL version works and looks sweet. Sent from my iPhone using Tapatalk
Dx7,T-550Ev2,T-450 pro Dfc, 130 X, mcpX BL Brushless Nano RUSH 750 being built To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#5 | |
Thanks, Dan
#6 |
No probs
I did the same with my 550E !!
#7 | |
+1 I've seen pics of a 500 with the extra tail control rod guide with the loop on top of the boom and the long antenna running through it running parallel to the boom. If I had mine mounted on the top of the boom mount, I'd probably do it that way.
Trex 500-3226-1600, 13T, Koby 90LV, HS-5245MG, DS520, AR7200BX, DFC Trex 450 Sport-450M, 13T, RCE-BL35X, HS-5065MG, HSG-5084MG, DS760 DX8 |
#8 |
Here are some pics of mine and how I did them
![]() ![]() ![]() I protected it with shrink wrap first so that it wouldn't come in contact with the CF frame then zip tied it half way down to ensure that it stayed in place
iKON field Rep GAUI NX4 with iKON, EDGE blades O.S.37 To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. GAUI X5fes, iKON, Edge blades, CC 20amp BEC pro, Align 600Npro, iKON, OS55HZ, Funkey B320 3D pipe, Radix Blades, |
#9 |
Look in the beastx manual, they show a pic of a trex 450...
Align 450 PRO DFC 4S KDE 450XF // Blade 450X 450MX, 3GX, Savox // Align 450 Sport V2 Airwolf Align 600EFL PRO, DFC, 3GX, KDE Align CHP DL 800, XERA 4530LE, ICE160HV, AR7200BX, SB-2271MG, SB-2272SG, KDE, Lynx, 115s Thunder Power 65C LiPo & JR 12X |
#10 |
The way they show it is too loop it back thru the anti rotation bracket and use it as an anchor.
I personally didn't like that at all. When you go full negative you would be hitting it
#11 |
no you drill a tiny hole in the anti rotation bracket right next to where the pin rides. then thread the antenna through. have it like this on my pro and it is tidy and looks great. Plus its what is recommended in the manual
Team Avant RC - Field rep * ProgressiveRC.com |
