| MSH Protos MSH Protos Helicopter Support Forum |
Hi, Just wanted to know if the Stretch Mini and the 500 fly much different. I have a Stretch Mini Protos is it worth buying a Protos 500 ?
![]() My other Heli is a Logo 600SE. I have a Logo 500SE I need to build yet. Thanks for your help. |
Well, you can never have too man helis...BUT, if you're trying to be practical then no, I wouldnt bother with the 500 if you have a stretched miniP already
2003 SVT Cobra 538RWHP 2010 Corvette ZR1 all stock To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Blade 450FBL, PRÔTOS 500CF FBL |
The P500 is way more powerful, but less agile.
Also flies much bigger and is much easier to see.
Lynx Heli Team Pilot Prôtos CF, 130X and many others. CarbonCore H6 650mm Wookong-M All on DX18! |
Thank you, someone said the 500 eats batteries ? They only get 3.5 min. Flights ?
#6 | |
I can fly gently(1) with my Protos with 2600mAh battery for 8-9 minutes. On the other hand slightly harder(2) and to push battery to its capacity after only 3 - 3:30. At each occasion to return around 1800-1900mAh to the battery. (1) - circuits, pirouettes, piro-circuits, gentle funnels all upright or inverted and all with around 2000 RPM head speed. (2) - elevator and even better aileron tic/tocs and full collective rainbows and similar - all at around 2900RPM head speed. Now when I think about it - it is similar to 2200mAh 3S on my MT... Actually - I think it is slightly more compressed with Mini Titan: 4-4:30 of hard flying with slightly over 3000RPM HS vs 7-8min on 2200RPM of gentle flying. |
#7 |
#8 |
I fly a stretch 500 on 3300s, and get 6min while putting back ~66%. I am just light sport flying @ 2600rpm while trying to dial in my machine and test the tail.
Another Prôtos owner here flies the plastic on 2600s, I believe, and he easily gets 8 min. I'm not sure of his HS, but I think it's lower than mine. Sent from my Tapatalk using iPhone.
Mini Prôtos AR7200BX Prôtos stretch AR7200BX Savöx 1250/1290MG SAB 470mm ALeeS Rush 750 YGE 120HV/4035-530 AR7200BX Savöx 1258/1290MG Rail 696/116 mCPx stretch uHeli head DX18 AMA# 448427 |
#9 |
My mini is 6s and I get 5 min no problem. Easy flying right now.
#10 |
I have a stretch mini and as soon as I get the brain and make sure I like how it flies I am building a (streched) 500 as well. Love the design of these helis
Now we just need MSH to make a 550, i dont really want a 12S setup just now...
-DX8 -MSH MiniProtos Stretched, SK720, DS95/DS95i, Hyp 4S 25C 2500mAh -MSH Protos Stretched, Brain, Hyp DS16/BLS251, 6S 3000mAh |
#11 |
Put VBar on my mini and it flies great !!
#12 |
If you are looking for a bigger help yes it is worth it.the stretch mini is still only 70% of the p 500. I have both and love em. after flying my mini stretch for about 2 weeks every day and ignoring my 500 i flew my 500 and almost scared me! A lot more power then the mini. Good pair to have. And no it does not eat lips. 6 min ave. And mine is stretched also
Keep it in the air! To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Lovin MSH! hybrid Gaz/otos fbl,stretched 6s MiniP Stretched PROTOS 500 ,EC135 Era/Protos500,Compass 6HV, Gaui NX4 all MSH-Brain/Futaba8FG Compass 3D+ CGY750 |
#13 |
On brand new 6s lipos I was getting 7 minutes with my packs coming down around 85F or so. Using a 14t pinion, governor off and idle up goes from 60% to 80%.
I still have lots of power and its my most agile heli, only bogs a little on climbouts. If you run a conservative head speed you can run the belt a bit looser and that will give great flight times. Also using 2650 or even 2800mah 6s packs will add 30 seconds to a minute.
Hoss X4e 6s, Gaui 550, Protos 500 12s, Losi Speed-T. Save the flybar !! |
#14 |
Don't mean to thread hijack but quick question... Whats the average crash cost dif and parts broken in a crash between a p450 stretched and a p500 stretched(not counting electronics)? Gonna get a 450/500 and have one (or both) be a nice beater heli and wanna know if there is a significant diff or not.
#15 | |
#16 |
The heavier the heli, the bigger the hole in the ground and your pocket after a crash...
Minicopter Diabolo - Kosmik 200 Cool, Pyro 800 Comp MA Whiplash - Kosmik 200, Pyro 700 Protos500Stretch-YGE90+3226-900 Protos500-YGE80+MVVS950 ProtosMiniStretch-YGE60+2025-1360 MSH Brain Spektrum DX8 |
