Old 06-28-2012, 03:54 PM   #1
soljkaer20
Default 130 X Gyro Gain Menu
Hi Guys,
Now that the 130 X is shipping now, we want to share our little secret about the gyro adjust ability.
This was not in the manual because it not required to fly the helicopter, we feel out the box the helicopter flies great for the consumer. However some of the consumers want this ability to tinker and play with it.
Below is the instructions on how to access and use the Gyro menu program in the 130 X.
Hope everyone enjoys their 130 X's!!
3-Axis Gyro Menu
To Enter Programming Mode
1. TX on throttle set to high (100%)
2. Plug the flight battery into the helicopter.
3. The Status LED will go solid blue, then there will be a sequence of Red, Green, and Blue Flashing LEDís
4. The RED LED will now be solid and the status LED will be flashing.
To change between axis use the Elevator stick.
Red LED = Elevator
Green LED = Aileron
Blue LED = Rudder
To change the gain value use the Aileron stick
There are ten steps available in either direction, total of 20 gain values for each axis.
The highest and lowest values are not high enough or low enough to cause not to be flyable. It adjusts the gain in a window we determined was useful to the consumer.
Right Aileron increases the gain, the LED lights will start flashing faster.
Left Aileron decreases the gain, the LED lights will start flashing slower.
When the Axis LED is solid that is default value (neutral gain).
To reset the settings to default
Hold right rudder for 5 seconds while in programming mode, there will be a sequence of Red, Green and Blue flashing LEDís to signify the default settings have been applied.
Rudder value must be at 100% travel for this to occur.
To exit the menu.
Simply just unplug the battery. Set the throttle to low throttle or throttle hold and re-plug in the battery.
Thanks,
James
Horizon Hobby Product Development
soljkaer20 is offline        Reply With Quote
Old 06-28-2012, 04:07 PM   #2
Liduno
Sticky this please.
180CFX MCPX-BL B400 130X MCPX 230S NANO-CPX NANO-CPS MSRX 120 SR MSR MCX
IF IT CAN'T BE FIXED WITH DENTAL FLOSS, THEN IT CAN'T BE FIXED..LOL
Liduno is offline        Reply With Quote
Old 06-28-2012, 04:16 PM   #3
toys2cars2toys
Great thanks James, I had guessed that it must be stick programmed due to the absence of programming ports in the photos
toys2cars2toys is online now        Reply With Quote
Old 06-28-2012, 04:54 PM   #4
liftbag
Originally Posted by Liduno View Post
Sticky this please.
+ 1
Gaui 200 Beastx - An unknown number of bl converted Blade mCP X.
liftbag is online now        Reply With Quote
Old 06-28-2012, 05:31 PM   #5
Nytro97
Its on the Blade site now.
http://www.bladehelis.com/ProdInfo/F..._Gyro_menu.pdf
Tom
Blade 550x,270CFX, 230s and DX9
Nytro97 is offline        Reply With Quote
Old 06-28-2012, 05:53 PM   #6
Cullen Colapietro
very cool! Thanks or this!
Only Fine Helis | Buddy RC | KBDD
Cullen Colapietro is online now        Reply With Quote
Old 06-28-2012, 06:01 PM   #7
Liduno
Originally Posted by Nytro97 View Post
Easier to find if it's a sticky here.
Old 06-28-2012, 07:51 PM   #8
Epoweredrc
Ooo wow cool
Sent from my ZTE-Z990G using Tapatalk 2
XK252,K120,Cpx450 ZYX,,Trex600 Beastx, Gremlin,POD Racer, GLH,Whipit,Z-84, Elelctric Shock AMA 27 yrs.
Epoweredrc is offline        Reply With Quote
Old 06-28-2012, 08:45 PM   #9
zeeflyboy
That's a great addition for those who like to tinker with different motors, blades etc.
Nice one HH, good to see you supporting the more "hardcore" fans too.
Blade mCP X - Brushless, XP-7A, HP05S
Gaui X2, BeastX/Scorpion 3400kv/YGE-30A/GS-093/DS95i
Align AH-1 Cobra (T-Rex 500)
Align T-Rex 600 EFL Pro, SK720/600MX/YGE-90HV/BL9180/BL9188
zeeflyboy is offline        Reply With Quote
Old 06-28-2012, 09:02 PM   #10
ChrisG23
Now if only the stock system supported governor mode, and swash had rear facing anti rotation pin.... oh well Not gonna stop me from purchasing.
ChrisG23 is offline        Reply With Quote
Old 06-28-2012, 09:43 PM   #11
RedOctobyr
Sweet, thank you James. And +1 to this. Flying great out of the box is awesome. But also being able to accommodate the people that want to tweak, modify, hop-up, etc, is fantastic.
You make the take-it-out-and-fly-it consumer happy, because it just works. And you really make the tweakers happy, by letting them adjust it to their flying style.
Nice work! I'm very interested to read the reports of how it flies!
RedOctobyr is offline        Reply With Quote
Old 06-28-2012, 10:40 PM   #12
TheHeliDude
Originally Posted by liftbag View Post
+ 1
Oh cool lift bag your getting one? If you can lift a gopro with an mcpx, then I wonder what you'll be able to do with this
nqx, mcpx, mcpx BL, 130X, trex 250 pro DFC iKon, 450X, TBS Discovery, Trex 500 DFC iKon, dx9
TheHeliDude is offline        Reply With Quote
Old 06-28-2012, 10:46 PM   #13
itsmillertime0
Reminded me of this gem of a post, lol.
Originally Posted by Souskei View Post
From what I'm hearing,
The 130x will eat any BL mcpx for lunch.
Thank being said, I really can't say.
If u look at the msr/120sr crowd,
The msr was still VERY strong after the release of the (including the mod crowd)
So I don't think the brushless mcpx is goin anywhere,
And in a sense, it's like comparing apples to oranges. 2 different class size birds for 2 different purposes i suppose.i
BUT I DO KNOW ONE THINGS FOR SURE!!!
Liftbag if gonna try to make it a 6s bird out of the box
Dylan is gonna make must have pieces
4217 is gonna make a program where the 130x can cut your homemade pizza and chop your carrots
Steffens gonna write the code for 4217 to do it
Roffey, NCcraig, and doubleCH are gonna suggest to the above people that it should blend margaritas as well
Aaaaannnndddd
TNT is gonna be the first to try it and show us a video of how he made a carrot pizza with his 130x and serve it with a pizza slice scooper attached to the skids that Dylan made, while drinking margaritas.
itsmillertime0 is offline        Reply With Quote
Old 06-29-2012, 02:19 PM   #14
rhemz
I have a really hard time believing that an mcpx can lift a gopro
rhemz is offline        Reply With Quote
Old 06-29-2012, 03:45 PM   #15
ebeing
130x | mCPX | mSRX | DX7S | mCPX BL
ebeing is offline        Reply With Quote
Old 06-29-2012, 09:56 PM   #16
Razzman
Default 130x-tail vibration, not smooth in hover.
Hello James and 130X pilots,
Thanks for the info on setting gyro gains. I tried a couple test hovers indoors this evening, but I initially found that the tail was acting like the gyro gain was too high, not being very smooth, shaking mainly side to side, also some up and down. Also when spooling up from soft start, the tail goes through a nasty vibration, looks like the tail blades are way out of track, until the head speed is stabilized.
This was with stock settings for hovering, idle up was worse. I lowered the gyro gain, although not sure if it's as low as it goes. This helped smooth the tail vibration some, although it's still not very smooth, still some side to side vibration, and up and down.
I played with the main blade tightness, and tail blade tightness in blade holders, as they sure were on the super loose side. I just took some of the excessive play out in the blade holders, but the blades can still pivot freely.
All gears seem to turn freely, just hoping I can get this heli to smooth out in a hover.
How smooth should the tail be? My MCPX was very smooth, no vibration.
Thanks,
Brian
"Wring it out"
Razzman is offline        Reply With Quote
Old 06-29-2012, 10:49 PM   #17
03Bugeye
Originally Posted by soljkaer20 View Post
Hi Guys,
James
That is right, we wanted to wait! And let ALL the mcpX owners know. That they have been shafted on gyro adjust.
No H8!! I plan on buying one of these!!!!
03Bugeye is offline        Reply With Quote
Old 06-29-2012, 11:02 PM   #18
tntburnett
Blade Forum Support
Thank you James for this info .
Be blessed
Isaac
Sent from my A100 using Tapatalk 2
Jesus Rep Its all Good,Its all GOD
FPV Everything Now
GOD BLESS
tntburnett is offline        Reply With Quote
Old 06-29-2012, 11:23 PM   #19
Cullen Colapietro
Thanks,
Brian
Brian, I know someone w/ a bad bearing in their tail pitch slider and it caused erratic tail behavior. jave you checked this bearing?
Old 06-29-2012, 11:53 PM   #20
itsmillertime0
Not your average mcpx:
