Go Back   HeliFreak > R/C Helicopter Support > Outrage RC > Outrage 550
Outrage 550 Outrage 550 Helicopter Factory Support Forum
Old 06-28-2012, 10:25 PM   #1
s0laris
Default DS610 Horns
I had transferred my DS610 Align circular horns to my Torq Cyclics on the O550, and they worked for a while..
My last auto was my "last" auto and I stripped a ton of teeth on my belt and busted 2 blades..
I also learned that every horn was stripped.. I thought it was the stupid elevator bell crank again, but nope!
I guess they are not as good a fit as I thought.. I put on the outrage ones. numbers 4 and 8 match what I used on the Align horns perfectly.
Just wanted to give you guys a heads up in case you did the same as me.. watch them horns!
Outrage 550, Goblin 630, 700, warp 360, Dual BL Mcpx, 130x
**When you start to be in complete control reflexes are not a requirement.**
s0laris is offline        Reply With Quote
Old 06-28-2012, 10:34 PM   #2
Slyster
I use Quick UK CNC horns... and they work great because of the bell crank system.. with 12+ crashes I've not stripped a servo yet.
It's not just a hobby... it's a lifestyle!
Outrage Fusion & 550 / Goblin 700 / SK540 / Kontronik / DX8 / Quantum / RJX / 4010 Duo
Pete Team Outrage.
Slyster is offline        Reply With Quote
Old 06-28-2012, 10:40 PM   #3
backburner1955
I use the Quick UK FBL wheels too... I like them.
AMA# 982814
backburner1955 is offline        Reply With Quote
Old 06-28-2012, 10:45 PM   #4
Slyster
I use the single arms.. I don't remember the size etc but they look like this
Pete Team Outrage.
Old 06-28-2012, 10:48 PM   #5
Grok
I use these Duratrax horns on mine. They come in blue, red or gold. Been working great since 2010. Work well with the original DS620s I had in it and with the Hyperion DS20X-SMDs I have in it now.
Grok is online now        Reply With Quote
Old 06-28-2012, 10:54 PM   #6
s0laris
Cant use single arms on bell crank.
But the stock torq horns should be good enough till I need to change them out.
Old 06-28-2012, 10:55 PM   #7
Slyster
opps yeah I was thinking of an older heli.. they are arms but double... and purple.
Pete Team Outrage.
Old 06-28-2012, 10:56 PM   #8
s0laris
do you have a link to the quick uk one ?
I use the torq 9180s
Old 06-28-2012, 10:57 PM   #9
backburner1955
If you want some stock Torq wheels, I have 2 complete sets of 4 if you want them. If you just pay for International First Class shipping, they are yours.
AMA# 982814
Old 06-28-2012, 10:57 PM   #10
Slyster
it's in here
http://www.espritmodel.com/search.as...d=quick+uk+arm
Pete Team Outrage.
Old 06-28-2012, 10:58 PM   #11
backburner1955
AMA# 982814
Old 06-28-2012, 10:59 PM   #12
Slyster
apparently I'm lazy
Pete Team Outrage.
Old 06-28-2012, 11:00 PM   #13
s0laris
oh esprit.. ok never thought to look there. thanks!
Old 06-28-2012, 11:01 PM   #14
s0laris
I have 12 round outrage cirtcle horns to use up..
so I will go through them all 1st lol..
Thanks!
Old 06-28-2012, 11:08 PM   #15
Grok
A couple of pics of their installation.
Old 06-28-2012, 11:16 PM   #16
backburner1955
This is what I run on all my helis.
AMA# 982814
Old 06-29-2012, 12:21 PM   #17
pctomlin
I use the round plastic horns on my servos. I prefer these over any metal horns because in a crash these will be the weak point. As you found, in a good crash the plastic teeth strip. It is much less expensive to replace a plastic servo horn than a CNC horn and/or the gears in your servo. Plus, the plastic horn teeth should be a little weaker than the linkage saving some damage to it also. After a crash it is something that needs to be removed and checked.
Paul
Outrage 550 - Castle 3434-1100, Ice 100, Bec Pro, 94758z, Total G w/JR 8900G
Outrage 550 - 4020-1390, Ice 100, Bec Pro, JR 8717s, Total G w/JR 8900G
Rave Ballistic FSO - HKIII 4035-560, Ice HV160, Bec Pro, JR 8717s, Total G w/BL-9188
pctomlin is offline        Reply With Quote
Old 06-29-2012, 02:05 PM   #18
s0laris
yes i totally agree with you!
Its super easy to swap them out and recenter with beastx.. takes less than a minute
Old 06-29-2012, 09:16 PM   #19
Grok
That's what's nice about the horns I've been harping here. Metal arms, but plastic servo mount insert.
