Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > Blade 450
Blade 450 Blade 450 Helicopters Information and Help
Old 06-29-2012, 11:36 AM   #1
Rocket2300
Default Thread Lock on the tail
I had a slight meeting with the ground and broke one of the ball arms on the pitch slider. I have stripped two 1.5 allen keys trying to get the grub screw out..any suggetions?
Rocket2300 is offline        Reply With Quote
Old 06-29-2012, 11:43 AM   #2
catpainkev
I'd get a high quality brand new allen key/screwdriver and try that
catpainkev is offline        Reply With Quote
Old 06-29-2012, 11:48 AM   #3
Bananaslug
I've had luck with CA on the end of the Allen key. Let it set up a few hours.
Bananaslug is offline        Reply With Quote
Old 06-29-2012, 01:26 PM   #4
celltech
I had the exact same thing happen to me last week. I was simply going to grease the thrust bearings and stripped everything out. The trick is too heat up the aluminium and that will loosen everything up. Of course this was found out after I had to cut my blade grips off to try and get the screws out.
Trex 600efl Pro,Beastx, Blade 450 3D, ZYX Tarot FBL, Blade 450 3D stock, MCPX v2, Sr120, Spektrum DX8
celltech is offline        Reply With Quote
Old 06-29-2012, 01:38 PM   #5
Rocket2300
It was a brand new e-flight allen key/screwdriver..must not be that good of a product.
Old 06-29-2012, 02:10 PM   #6
Relisys190
I've done this, it's not fun
Eat. Sleep. 3D
-Markus
Relisys190 is offline        Reply With Quote
Old 06-29-2012, 11:45 PM   #7
gdawgs56
i, just used a dremel and cut a little straight line in the head of the screw and then used a flat head screw driver. I found the flat head screws dont strip the head of the screw as easily. I hope this works for you!
TEAM HELIPROZ
450 FBL: Scorpion -8 motor, Tarot ZYX Fbl
130X: HPO8, DS35, Lynx, Rakon, KBDD, Fusuno, DIY mods
NANO CPX BL: SOLD
gdawgs56 is offline        Reply With Quote
Old 07-01-2012, 03:19 PM   #8
Rocket2300
good idea!
Old 07-03-2012, 11:01 AM   #9
Belgarath
I was having this issue because I was using the provided allen key. (I bought what I thought was a better kit that was not good either, as its 1.5mm was about 1.8mm and did not fit) Once I used a quality key though, the difference was so big I was shocked. I really didnt think that the quality would make that much difference a tool that seems so simple.
Belgarath is offline        Reply With Quote
Old 07-03-2012, 11:35 PM   #10
Thalios
Heat it with the tip of a soldering iron. (Just the screw).
This will break the bond of the loctite.
Lynx Heli Team Pilot
Prôtos CF, 130X and many others.
CarbonCore H6 650mm Wookong-M
All on DX18!
Thalios is offline        Reply With Quote
