Go Back   HeliFreak > R/C Helicopter Support > Thunder Tiger 30/50
Thunder Tiger 30/50 Raptor 30, Raptor 50 Helicopters
Old 07-01-2012, 04:10 AM   #1
fourbie
Default Engine temp
I never got to grips with touching an engine to see if it is too hot so I have a non contact IR thermometer coming. I did a search but came up with nothing so can you tell me what the too hot temp range is for an OS 32.
Have a great day - John
"Do it to them before they do it to you" {Hill Street Blues}
When the blue light is flashing I am kidding. E&OE.
fourbie is offline        Reply With Quote
Old 07-09-2012, 07:17 AM   #2
joecass2
aroud 200f. anything over 220f is to hot
joecass2 is offline        Reply With Quote
Old 07-09-2012, 01:09 PM   #3
fourbie
So if I can get 185°F or thereabouts that will be nice????
Old 07-09-2012, 02:37 PM   #4
AKPhill
190 would be better on the cylinder just below the head
AKPhill is offline        Reply With Quote
Old 07-09-2012, 02:40 PM   #5
fourbie
Smack dab where it says OS32??
Old 07-10-2012, 01:12 AM   #6
AKPhill
Right at the top of combustion chamber and below the head
Old 07-10-2012, 03:20 AM   #7
fourbie
Marked in red!
Name:	OS 32 WMF.JPG
Old 07-10-2012, 10:11 AM   #8
AKPhill
NO that is the cylinder wall .
Move toward the head where there are fins on the cylinder just before it turns into the head
Old 07-10-2012, 11:07 AM   #9
fourbie
OK thanks.
Old 07-11-2012, 08:07 PM   #10
Avidflyer
There are waaaaay to many variables to tune based on temp alone. For instance 5 different replies on where to measure? How long do you let it idle before checking? Check it running or not? What's the outside air temp? All of these could change your measurements by a huge margin. Your best bet is to learn to tune by sight, sound, and performance as thousands before you have. If in doubt run it slobbering rich and lean it a click at at a time. And touch the backplate not the cylinder. General rule of thumb is if you can hold your finger there a few seconds you are prob good. 50s are VERY forgiving compared to the big boys.
Blade 400 Hughes 500 Scale
Align 450 ProV2 3GX V2.1 450 Sport FB aka "The Beater"
Raptor 50 V2 OS50SX-H "Ol Faithful"
Align 700N LE BeastX
Avidflyer is online now        Reply With Quote
Old 07-12-2012, 10:27 AM   #11
Kneedragger75
Exactly. You are overthinkink this heat gun thing. The backplate is the usual place to check temp, not the cylinder. What will you do if you see a temp
way to high or low when experimenting with this device? Turn the needle 2 turns in?
Tuning a nitro engine is half science and half art. It takes a good ear to get it right.
As mentioned, start way rich and tune leaner untill power peaks and exhaust note
is smooth and crisp.
Use the laser on the temp gun to chase the cat.
Raptor 50 OS50 Hyper, Futaba 520
Miniature Aircraft Furion 450, Spartan Quark
Futaba 9CHP
Kneedragger75 is offline        Reply With Quote
Old 07-12-2012, 01:57 PM   #12
fourbie
General rule of thumb is if you can hold your finger there a few seconds you are prob good. .
To me that is a temperature check!
Old 07-12-2012, 02:44 PM   #13
rcflier1
and talking to ys today, i was told the only temp check is on the head, in the plug area. the temp there sb 220f or below on my ys56sr.they were not a fan of the finger on the backplate method
rcflier1 is online now        Reply With Quote
Old 07-12-2012, 02:50 PM   #14
fourbie
I'm not too cos I don't want a burnt finger.
Main reason for the IR Temp gun was to use it to CONFIRM when I think it is running too hot, not as a tuning tool per se. Once I find a good spot to check the temp it will also act as a bit of a baseline.
Old 07-14-2012, 12:28 PM   #15
rcflier1
ok, on my still new ys56. the head was 178, the cylinder just below the head was 200, and the engine ran fine.fuel was 15% ys blend and air temp was about 85
Old 07-14-2012, 03:25 PM   #16
Kneedragger75
You guys are fooling yourselves if you think shooting an IR temp gun at an RC engine is going to give you any valuable data. Try the same experiment 10 times, and shoot the
gun in slightly different places at slightly different times and report the results.
Tune the engine properly and go fly.
Don't get me wrong, I love experimenting and collecting data. I just have found this particular experiment
fruitless.
Futaba 9CHP
Old 07-14-2012, 05:34 PM   #17
rcflier1
your right in that 20 sec later will give different readings.but, after blowing a hole in the piston i,m trying to be safe.running glow in planks is a whole different world. i,m still trying to get it right in heli's
Old 07-15-2012, 12:02 PM   #18
fourbie
fruitless.
It's simply another way of checking things.
