Go Back   HeliFreak > R/C Helicopter Support > Henseleit
Henseleit Henseleit Helicopters
Old 07-02-2012, 02:54 PM   #21
Stolla
none of that crap since I changed to beast x, certain elevator movements on vbar causes hectic responses, been there done that! Especially in gusty conditions its a bitch.
Old 07-02-2012, 03:15 PM   #22
marcosp
Yeap, though the 5.3 update is pretty solid. I agree with Danny that a mechanical failure is also possible.
Marcos
Banshee #27, 2x TDR, Diabolo, JR Sylphide E12, Voodoo 600, Voodoo 400, Avant Aurora 90N, Rave 450, Gaui X2
marcosp is offline        Reply With Quote
Old 07-02-2012, 03:26 PM   #23
jamin_00
Trouble is its hard to say.
I still have to download the log to see what that says.
Sponsored by
Optipower
jamin_00 is offline        Reply With Quote
Old 07-02-2012, 04:30 PM   #24
rctintin
Put a BeastX on there Ben!!
Henseleit TDR V-Bar
SAB Goblin 700 V-Bar
Synergy N5c V-Bar YS56
T-Rex 700 V-Bar YS91SRS Futaba 18mz PL8x2
rctintin is offline        Reply With Quote
Old 07-02-2012, 04:59 PM   #25
Vinger
Never had it, but when I had a BeastX on my TRex500 it ballooned for any bit of disturbance, when my repaired VBar came back, fit it and it was and still is rock solid. I believe it is all in the setup and using the right blades for what you want to do. All my VBar equipped helis fly rock solid at speed, TDR with mini blue, Radix standard blades has done 239kmh in level flight with no bad tendencies.
Any heli will pitch violently at speed if you hamfist the controls, remember to use lots of expo and less cyclic if you want to do the speed runs and this is where the banks on the VBar come in real handy.
TRex 250 BeastX, Trex 500-Vbar 5, Henseleit TDR, Banshee -VBar 5 All Kontronik ESC
Hyperion 1420, Mega Power Gemini Chargers! JR XG11
Old hand at Planks
Vinger is offline        Reply With Quote
Old 07-03-2012, 12:16 AM   #26
Stolla
can't speak for trex but I had just the opposite 3 tdr's on vbar switched to beast x, day and night difference, it doesn't care which blades, been using vbars since first versions came out, not anything anyone can tell me about setup with vbar. Haven't tried latest version though but merely the fact that they claim its better is acknowledgment it didn't work perfect before. But just my opinion...although I don't think there's many vbars at speed cup events in germany from what I heard. But I can say this running 100% thr on 1.6 mm. yy winding,4035 motor 560 kv 15t pinion 14 deg pitch pulling out of a high full speed knife edge dive 2 m above the ground is no problem for beast, something I would never even attempt with vbar. I haven't logged yet but did log the same flight pattern before on weaker motor governed at 65% 510 kv, at 242 kmh so imagine the difference in headspeed from a high dive. Setup on beast takes a little more knowledge of fless systems as they don't have the easy setup pages like vbar, although easy to setup a little more difficult to get perfect. And I'm not against vbar, still have them on all my 3 d machines some with vbar gov which is excellent again just my opinion!
Old 07-04-2012, 01:03 PM   #27
jamin_00
Bits arrived this morning but I'm missing the TT drive shaft Email sent, hopefully receive it before the weekend???
Sponsored by
Optipower
Old 07-04-2012, 01:36 PM   #28
marcosp
I've been waiting for parts from Jan to reconstruct my rotor head for 28 days and counting, not even arrived to my country........
Marcos
Old 07-04-2012, 02:11 PM   #29
jamin_00
Oh damn, I got an email about 1/2 hour after I placed the order to say they on the way and obviously being close to Germany they only take a couple of days.
I ship stuff worldwide from work and excluding customs can get goods anywhere within 48hrs so its possible
Sponsored by
Optipower
Old 07-04-2012, 03:10 PM   #30
marcosp
Yeah, too bad Jan doesn't use EMS, only regular mail. In my case this means it is always stopped by customs and I must go pick it up, even for a $20 box, times are absolutely variable, the fastest was 8 days, very normal between 8 and 15 and this the longest at 28 without any news yet of arrival in the horizon.
The heli is still in flight though with a shake I am 99% sure is a bent main hub.
I read yesterday some people claim the SpinBlades Matt Black go out of track at high pitch. I am having visible shake on the canopy at high pitch........... Once I solve the regular shake I'll see if this other one persists and try other blades to rule that out.
Marcos
Old 07-04-2012, 11:56 PM   #31
Stolla
did you roll your spindle on glass surface to check (listen) for bend, logo shaft drop in btw, and doesn't bend in flight!
Old 07-05-2012, 07:34 AM   #32
marcosp
Yeah, happens with brand new spindle too. I already ruled out everything, every bearing, blades, gears. It's a shake so not in the frequency of the tail. I don't want to hijack the thread, we discussed this, thing is it's been a month since my hub and blade holders shipped from Germany.......
Marcos
Old 07-10-2012, 09:07 AM   #33
jamin_00
guys, I don't think it was a retreating blade stall the more I analyse what happened. Surely a roll would have been the first evidence of this yet I had none. I know it happened very quick but it was defo only ele that gave up and I suspect this was due to the servo not having enough torque and the vbar not compensating for this with the front servos.
So I have gone with some BLS157's which have more than 3 x the torque so should be enough for it
Then I may even try the Beastx as I do see a few commenting about this over the vbar but I don't know on that yet.
Sponsored by
Optipower
Old 07-10-2012, 10:30 AM   #34
ZuvieleTeile
Originally Posted by jamin_00 View Post
guys, I don't think it was a retreating blade stall the more I analyse what happened. Surely a roll would have been the first evidence of this yet I had none. . .
Imho a retreating blade stall will result in a pitch up because of the gyroscopic precession . . .
Kind Regards ZT - TDR, Logo-400SE
No problem can be solved from the same level of consciousness that created it.(AE)
ZuvieleTeile is offline        Reply With Quote
Old 07-10-2012, 03:43 PM   #35
marcosp
Should be up and right on a normal clockwise rotor, don't know with FBL.
Marcos
Old 07-10-2012, 04:15 PM   #36
Mercuriell
I'd agree - good point. Seems worth keeping HS up anyway.
John
Mercuriell is online now        Reply With Quote
Old 07-10-2012, 04:17 PM   #37
Vinger
Banshee did the world record with TDR head and 451 servos!
Old hand at Planks
Old 07-11-2012, 12:04 AM   #38
marcosp
And Jamin's Rotortech blades? Makes ALL the difference...
Marcos
Old 07-11-2012, 04:35 AM   #39
Mixmaster Pilot
Yes it pitches up due to gyroscopic procession, but it also rolls right at the same time (in a clockwise rotating rotor) from the loss of lift from the retreating blade.
If it's just a pitch up it's not RBS.
Compass Atom 7HV, Scorp HK3 4035 hand wound by Mauro - 6x7x1.32 YY 430KV, CGY750
Beam E4, 6S, looking for a new FBL unit, BX is getting removed!
Formerly owned - Blade mCP X V2 - Blade 400 FBL BeastX
Mixmaster Pilot is offline        Reply With Quote
Old 07-11-2012, 05:17 AM   #40
Vinger
Roll the FBL units can keep it in check, same with flybar, although at slower speed. If the retreating blade stalls it also precess through 90 degrees and cause a severe pitchup. Mikado changed the way the cyclic ring interferes in 5.3 to allow larger pitch changes to enable the head to be more stable at high speed!!
See
http://en.wikipedia.org/wiki/Retreating_blade_stall
http://www.copters.com/aero/retreating.html
http://www.helis.com/howflies/maxspeed.php
http://helicopterflight.net/rbs.htm
Old hand at Planks
