| Blade 450X Blade 450X Helicopters Information and Help |
Flew my 450x today for the first time, but this was almost catastrophic. First, running stock 450x blades and edge tail blades. I Lifted off into a very smooth hover, hands off to check for drift and it was dead still no drift at all. I then flew around to check the rudder and cyclic response and all was good there also. At that point I decided to check the tail gain so I flipped into idle up 1 and the heli quickly rolled over on it's right side. That really got my attention, so i quickly added left cyclic and flipped out of idle up mode and the heli was very stable and controllable again. This is my first electric flybarless heli. Any ideas guys on what to check here?
Also, when I got home I wanted to checked the throttle hold switch for motor cut and when I turned the hold switch "on" the blades started to spool up slowly why? This should cut motor power correct? My throttle hold setting in my X9503 is at 0%. How should I setup throttle hold? Must I give a - % value in hold instead of 0% to stop the motor when throttle hold is on? |
This is the standard BeastX reaction when it gets too much vibration. Put the factory tail blades back on and check it. If the problem goes away, it means you have a set of mis-balanced tail blades. I had the same thing happen with a pair of aftermarket tail blades. If it's not the tail blades then it's time to go on a vibration hunt around the helicopter. The reason it's happening in IU and not in "normal" is probably because the vibration isn't severe enough to manifest at lower head speed, and once you kick the speed up, it pushes the vibration beyond what the BeastX can handle.
Stop making excuses and fly the damn thing! B130X (x2) B450X (x2) T-Rex 550E, 700E, Goblin 500, 700 Habu 32, Extreme Edge 540T, various foam junk |
There was at least one other post on here where someone had the same exact problem with the edge tail blades. They may be out of balance.
Rodney Synergy E7, Synergy E5, Synergy N5C, Blade 130X |
Thirded, swap back to the stock tail blades, see if the problem goes away. And definitely balance your tail blades as well as your mains.
Far as the slow spool-up, I really have no idea on the JR radios. As far as the DX6i goes, the reason the manual says to set 10% on throttle hold is because low-stick is actually sending 10%... it has an upward offset, while TH can send an ACTUAL 0%, so if the heli ever sees TH on (giving a real 0%) then switched off (jumping to 10%, at the bottom of the collective stick) it may start to spool up as it resets its 0% mark to the lowest value it's seen. But if the cases were similar, it'd stop spooling with TH on, and start as soon as you switched it off TH.
Blade: mCX2, mSR, mSRX, Nano-CPX, 2x mCPX (v1), mCPX-BL, 120SR, 450 X Spektrum DX8, DX6i |
#5 | |
Team Newb Pilot 450X (6S Scorpion 2221-2010, Spektrum H3000, MKS DS95i, Ice Lite 50); 300X (Spektrum H3000, Hyperion DS11GCB, HiModel Cool 33A/Don's RC Wicked 4800kv); TRex 250 Pro DFC (250MX, MicroBeast, Phoenix 25); 130X HP10S; mCPX BL; NanoCPX. |
#6 |
Do y'all measure tail blade balance with a scale, because tail blades wouldn't fit on my blade balancer so I've always just checked they weigh the same
Blade Mcpx - Spin 16.3 - all MicroHeli Blade Mcpx BL, Blade 130X - HP08 Blade 450X - Scorp 2221-6 DJI F450 Naza, Trex 500 DFC |
#7 |
That's all I ever do for tail blades, hasn't failed me yet, but I have only been in the hobby for 6 months or so.
#8 |
Edge tail blade problem here at one point. Ran up the heli with only the tail blades on....Serious vibration. They seem to have a really bad balance out of the box.
Tarot 450 Pro V2 DFC 6S - Scorpion 2010 - YEP 45A - Hitec 5065 - Hitec 5084 - Robird G31 Trex 500E DFC - Castle Vertigo 1800 - Castle ICE75 - DS510M - DS520 - AR7200BX MSH PRÔTOS - Scorpion 880 - YGE 60A - Futaba 9650 - Futaba 9254 - AR7200BX |
#9 | |
Then they're balance from the bolt holes to the tip.... Then use a fine scale to make them of equal weight. FWIW |
#10 |
In regards to the above started thread. I'm happy to report, problem solved with the bad right roll when going into IU mode.
This is what I did, I put a set of "Blade" carbon fiber tail blades on period. I did not balance them, just put them on and smooth as glass @ 3100 rpm ![]() |
#11 |
My money's still on badly-balanced EDGE tails, and the official ones just being balanced well out of the box.
#12 |
+1. Glad to hear the stock CF blades are working for you. I've chocked my experience up as a lesson learned on not breaking something that doesn't need fixed as my tail authority is great with the KBDD blades and they are very visible. Unless I start having a problem with the holes being elongated like some have reported or other issues I'm likely to leave them alone.
