| Outrage Fusion 50 Outrage Fusion 50 Electric Helicopter Factory Support Forum |
| View Poll Results: T-Rex 600 efl PRO or Fusion 50 FBL? | |||
| T-Rex 600 efl pro |
25 | 28.74% |
| Fusion 50 fbl |
55 | 63.22% |
| Other |
7 | 8.05% |
| Voters: 87. You may not vote on this poll | |||
I would like to know the impressions of you about these 2 machines.
Please, only guys that already piloted both helicopters. .
Fusion 50 FBL * Mini-Vbar * 10s battery * CC Phoenix ICE2 80HV * Scorpion 630KV To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Last edited by nivaldin; 07-12-2012 at 06:22 AM.. |
flown both not a fan of the Align at all. not happy unless its being flown at 2600+ rpm..
smaller packs.. smaller motor mount allowing a VERY small amount of motors.. servo setup.. Fusion happy all day long at 2200 and screams doing it can handle HUGE 700 class motors can handle 3700 packs stock.. bigger with aftermarket tray easy to build and maintain.. my only whine with it.. gyro tray blows.. big hassle if you dont want to use a full size vbar..
SAB USA Field Rep, Skookum Field Rep, Team Lynx. Goblin 700, Goblin 630, Goblin 500 |
Love the 600 pro running 2250 havent been able to blow out the tail as of yet.
Sent from my DROID RAZR using Tapatalk 2
[Trex 450 PRO V2 3GX, Edge] [Trex 500 ESP(DFC) ICE100, 3GX, Edge] [Trex 600 DFC PRO SK-540 ] [Rave ENV Nitro O.S 105-R,Total G,Outrage, Edge SE 713] [Blade 130X] |
I just sold my 600EFL Pro to build a second Fusion 50. I hope that is all that you need. The F50 is just a more solid design and so much easier to build, setup, repair and fly. The 600EFL needs alot of finessing to get it solid.
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. AMA# 982814 To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Last edited by backburner1955; 07-03-2012 at 05:33 PM.. |
Ceevee not sure what you mean.. the mini-v is not a hassle at all! It fits right in there and there is a hole on the top for the cord right about the usb port.
See it tucked right in there?
It's not just a hobby... it's a lifestyle! Outrage Fusion & 550 / Goblin 700 / SK540 / Kontronik / DX8 / Quantum / RJX / 4010 Duo Pete Team Outrage. |
#6 |
The two birds don't compare really IMHO. The Trex, although nice, just feels weird to me. I have flow both. The fusion feels light and floaty whereas the Trex 600 feels fast and twitchy. Not to say the Fusion isn't fast. You can't go wrong with the F50. After getting my first one I sold my Trex 600 and got another Fusion.
#7 | |
I know when I tried to do an SK540 or a 3gx or a BeastX none worked well there at all. on the 3gx and BX you cant program with it mounted.. and the 540 the USB is biocked.
#8 |
On my Night fusion I have my BX mounted there and I have no issues programming it.
#9 |
I hate my fusion and love to death my 600 pro
Why does everyone keep calling me Dan? My name is Dante To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#10 | |
I sure as hell cant. the viewing angle would be super extreme to see the LED and especially the letters on the unit to know what step you are on.
#11 |
No.. there is a hole on the ESC tray (near the caps on my Kontronik) large enough for the USB to pass through right smack about the USB port on the Mini-v.. it's perfect!
#12 | |
thats where i have my beastx mounted and have no issues seeing the LED or which letter im on. i actually have it mounted to the back end of the gyro plate. i can even stick a long screw driver down the hole in front of the esc to adjust my pots
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Team A-Main/ProTek Field Rep. |
#13 |
I mount my beastx on the side of the frame. No issues 100+ flights.
Outrage 550, Goblin 630, 700, warp 360, Dual BL Mcpx, 130x **When you start to be in complete control reflexes are not a requirement.** |
#14 |
well, i haven't flown a 600 pro, but i've pretty much only flown align since i started, and after a lot of research i opted to try out a fusion. Haven't had any issues with it, or the way it flies. still getting used to a bigger than 500 class bird and the whole fbl thing, so it's tough to make a serious call between the two. buuuut i got a fusion, and that's why i voted fusion.
Thank god i have snowboarding to keep me occupied when its too cold to fly! To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#15 |
Did you have some issues with fusion?
Did you fly a Fusion 50 with well done setup?
Fusion 50 FBL * Mini-Vbar * 10s battery * CC Phoenix ICE2 80HV * Scorpion 630KV To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#16 |
I HAVE 2- GREAT -SMOOTH- EASY TO REPAIR -AND IT WILL TAKE A CRASH NEVER HAD A PROBLEM WITH MINE
#17 |
Did I have issues with my fusion? YES! and that is an understatement. Do I have issues with my fusion? YES. and thats an understatement. My four other birds are all Align, each set up and built the same way and i love em all. Bought a f50 tried to set it up the same way and its been nothing but disaster. But I hope you like yours. I've heard its a great bird, though i cant verify. LOL.
#18 |
Dante... make up your mind man, one day you hate this heli, next thing you know you love it because you got it set up correctly... now you hate it again. People make mistakes, were human... somebody sent you the incorrect parts that's all. I hope you get it all straightened out soon and I feel your frustration... but I think you are overly exaggerating the situation here.
Most of your prior issues were setup issues, you even admitted to it. Incorrect LiPo's, gearing, head settings, etc... Most of us in here have had a great experience with this heli... my Fusion has over 40 hours of flight time on it without a hitch. All I ever get is complements at the field on how smooth this thing flies.
~Outrage~ Fusion 50 (FB) ~Compass~ Warp 360 ~Blade~ mCP X (BL) AMA# 977012 **Team Boca Bearings****Team LYNX Heli Innovations** The member formerly known as Vicovaludemero |
#19 | |
Team Kontronik Team minicopter Diabolo Kosmik 200, Pyro 750 - 560kv, HC3X, BLS 255/256 |
#20 |
Yeah, I would not take his advise on a bird. His set up was so messed up initially it was a not wonder he hated it. He was trying to fly a 600 class bird on a mCPx motor... Or something like that.
Either way, you can't go wrong with the Fusion. You will be VERY happy with it. Get off the Trex bandwagon and try something new. You will be satisfied. |
