| Mikado Logo Helicopters Mikado Logo Helicopters Discussion |
#41 |
I finally fixed my tail vibe issue on the 500SE after replacing pretty much all the tail parts several times over and trying every option I could think of over the course of the year.
Last week I dumb thumbed it inverted backwards into the deck - broke most of the airframe so not much to salvage. I won't be buying another Logo to replace it - was far too frustrating. ![]() |
#42 | ||
Take it apart, inspect every individual piece, reassemble it correctly.....go fly |
#43 | |
look at your washers. if they look cheep. buy these. http://grandrc.com/QuickUK-General/c...duct_info.html
Greg Lynx Team Pilot Heli: TDR; Logo 600,500; Trex700E,500,450,250 Flight video: http://www.youtube.com/watch?v=GUkswcoyGEk&feature=plcp |
#44 | |
#45 | |
#46 | |
what I do, is I completely assemble the tail onto the boom without the belt. tighten every thing up. then i spin the tail hub, you get a better spin with tail blades on. it should spin for a while. if it doesn't. then start loosening the bolt until you figure out what is binding it. on some of my logos I couldn't use any shims in the hub.. and had to make the pulley thinner with a file..... but that came back to bite me with my 500. when I put an carbon SE tail on my 500 two shims where not enough. I needed like 8 of them. I used hobbyking 450 pro main shaft shims.
#47 | |
#48 |
I struggled with the 500se vibration for a month. Wasted a lot of good flying time. These are the things that I find that contribute to the vibration.
I think the length of the SE boom make it more prone to vibration c/w a 500 because it's longer and therefore less stiff. A shorter or a larger diameter boom will be less prone to vibration. Tail blade balance and quality is critical. Edge main blade are great but there is a batch of really bad tail blade and I did not realize it until I switch to plastic KBDD tail blade after trying two brand new set of edge tail blade to fix the vibration. The rudder control rod guide position can affect the vibration because the rod will vibrate like a string in a musical instrument and amplify the tail vibration. I move it away from the midpoint and the vibration is significantly less and one can add an extra guide if needed. Switch to the plastic tail case. I hate the way the plastic clamp for the CF tail work. Once you tighten the clamp the boom is deformed and there is no adjustability after that. Than there is the problem of getting everything square up and to make sure the bearings are not binding etc. etc. "Downgraded" to a plastic tail and no more headache. So after a month of disassemble reassemble, new parts after new parts(tail shaft, bearing, shims, new boom, new tail assembly) for the CF tail with no success, the fix for my 500se was plastic tail case with new tail shaft and bearing, kbdd blade and move the control rod guide position. Hope this will help someone. |
#49 |
Got mine fixed!!
![]() I think it was the bolt that holds the 2 spacers and the bearing that goes over the belt and pulley. I noticed that I had that one too tight. The spacers were compressed to the point where the carbon sides were looking a bit warped. This is just guess because I tore the damn thing apart at least 12 times. I'm just glad it works!! Now I can fly it! ![]() |
#50 |
Nice!!!
