| Genius CP Walkera Genius CP Helicopter Support |
hello ,
did any one have this Walkera Genius CP brushless upgrade parts brushless kit installed in Genius CP ? i can't get it works follow the instruction from the packaging . power up the Tx and Genius. move the throttle up. the main and tail motor does not work ? what else did i miss ? cannot find any instruction from Walkera.com http://www.oomodel.com/walkera-geniu...t-p-62027.html thanks |
I just got my brushless kit today. the problem I am having is that the motor is spinning the wrong way. looks like we're both having some bad luck
#4 | |
Reverse the wires coming from esc to motor.
AMA 988334 Walkera- Genius BL, 4g6, 4g6s, v120d02 2s, v450d01 TA Trex- 250 Mikado fbl conversion rx2702v, clone 500 fbl rx2702v X7 Edge BeastX Savox Scorpion CC Ice2 HV120 To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
got mine solved.
1) plug in lipo , wait for the heli to power up. 2) once heli power up. 3) move throttle stick to high, hear some beep sound. then 4) move throttle stick to low, hear some beep sound. 5) you are ready to fly . |
#6 |
Glad to hear you solved the problem, have you flown the bird? Be happy to hear on your feedback my brushless conversion is in the post.
#7 | |
two brushless conversion is heavy. i felt no power. cannot find specification on the main motor. not sure about the KV. sorry , i might take away the tail motor to make it lighter and see how it goes |
#8 |
Yeah; it's pretty popular opinion here that the Walkera dual brushless setup is lacking at the tailrotor end. The common answer is to keep the stock tail motor & use a tail rotor with more aggressive pitch like the one for the Blade mCP X/2 tail rotor (Blade Part # BLH3603). $1.99 at my LHS, and normally stocked part.
mnem Rowwwwr! |
