| MSH Mini Protos MSH Mini Protos Helicopter Support Forum |
Hey guys, I'm a relative newbie (BL mcpx) and might be getting the Blade 450x as my first 'big' heli. Once I get better on that, I would love to get a Mini.
I wanted to know what parts, if any, could be used in the Mini. Would love to minimize the upgrade cost as much as possible Or any other suggestions are welcome! Thanks |
Perhaps the blades?
Go straight to the mini, you won't be disappointed |
+1 :)
http://www.xs4all.nl/~rzavelli/rc_heli.txt |
There is probably only 1 piece off the 450x and that would be the BeastX/Spektrum FBL controller. You can't use the motor, the servos are not worth moving across, the ESC with the mini Protos is much better, maybe the Lipo packs but really it's not worth it.
You would be better off selling the 450x as a unit and getting the mini Protos when ready or just go for the mini Protos to start with. //Dennis.
Mini Protos FBL Stretch - 4s MSH Brain : Protos FBL Stretch - SK-720 : Protos FBL Stretch Night flyer SK-720 SAB Goblin 500 Ikon : Logo 600 FBL V-bar, 10s : SAB Goblin 700 Vbar, HK5020, Hawk 120A |
From what all of you are saying... skip the 450x and get the Mini.
How much is the "average" cost of buying/building the Mini? I know it really depends on the parts, but could you guys please give some examples? I'm putting together a budget and would like to have a decent idea. Also maybe include the most likely to need spares? Thanks |
#6 |
If you've never built a heli, a mini might be a bit of a beast to start with.
It will cost you more than double what the 450X is. I'd go with the 450X, then sell it and get a mini. Parts availability will be easier on the 450X. you WILL crash.
Lynx Heli Team Pilot Prôtos CF, 130X and many others. CarbonCore H6 650mm Wookong-M All on DX18! |
#7 |
I thought about the 450X, but went with the mini as my first big heli.
I wanted to avoid the upgrade costs I experienced with BL mcpx's, so went the best straight away. But if on a budget, i would get the 450X, fly it, crash it, rebuild it a few times and any upgrades i did I would make sure were things I could carry over to the mini, you could def use the AR7200BX, and if it uses micro servo's you could get some nice ones for the 450X and carry them over. Most mini p's cost around $1k to get in the air, you can build cheap for $600 and best of best for $1200.
Minicopter Diabolo - Kosmik 200 Cool, Pyro 800 Comp MA Whiplash - Kosmik 200, Pyro 700 Protos500Stretch-YGE90+3226-900 Protos500-YGE80+MVVS950 ProtosMiniStretch-YGE60+2025-1360 MSH Brain Spektrum DX8 |
#8 |
Started with a mCP X last summer.
I went with the Mini Protos as well as my first proper heli, last November. Went with high end components straight away. Never regretted it, 300+ flights, still waiting to crash it for the first time. Know it will happen at some point though. It is possible to push your boundaries hard without putting it in, simply because it flies so well. It's bad-ass, might be a bit intimidating at first, but every heli prolly will be.
#9 |
I get all of your opinions/responces... Thanks!
I'm actually pretty mechanically inclined, like to work with my hands and build things. I also LOVE the way the mini sounds (I'm a music producer and my ears are finicky with sounds I'll most likely go for the Mini off the bat. If/when I crash, so be it....it'll make me a better pilot! Would a couple of you mind listing the parts you built with, including rough costs? I'll do all the usual rabbit-hole web searches, but would be great to get a solid starting point! |
#10 |
You might want to reconsider the Heli not the Brand.
A Protos 500 should come in near the same price and is probably a better bird to learn. Just one person's opinion.
Synergy E5-S KDE 600XF MKS HV YGE Vbar : Compass 6HV Quantum 4125 MKS HV YGE Vbar SAB G500 Savox 4050 KST/MKS HV YGE HC3SX Compass Warp Scorpion 2520 MKS YGE SK540 : 130X MCPX BL Nano 14SG DX8 |
#11 |
My comment might have come on the wrong side.
The Mini is 10 times better than the 450X. For many reasons. I went with this: MSH Brain (Flybarred at the moment obviously) Spektrum H3000 on cyclic Futaba S9257 on tail Gens Ace 3S 2200MAh 25C AR6115E receiver (From my old Blade 450 3D hehe) MSH YGE ESC MSH Scorpion stock 3S motor Stock SAB blades. Everything stock. That thing is a BEAST compared to the Blade 450.
#12 |
The thing that stopped me getting the Protos 500:
All parts are a little bit more expensive. Mains are a lot more expensive. Packs are a lot more expensive. A pain to get fbl, requires a few upgrade packs and if u want the best, you have to stretch it I wanted the best mini p so went with: Full stock kit 6S motor Alu servo mounts Alu 3rd bearing block Alu pulley Alu tail pulley Low fbl head MKS DS 95/i Vbar mini Stretch kit(flew standard for a couple of weeks, just stretched after an epic crash) 1300mah thunder power 65c packs I have had 3 crashes, all because of a mechanical fault, due to my noob building skills, 2 cost <$25(main shaft, feathering spindle, tail shaft and tail blades), the epic was around $100(main blades, frame, motor mount, and all the shafts)
Minicopter Diabolo - Kosmik 200 Cool, Pyro 800 Comp MA Whiplash - Kosmik 200, Pyro 700 Protos500Stretch-YGE90+3226-900 Protos500-YGE80+MVVS950 ProtosMiniStretch-YGE60+2025-1360 MSH Brain Spektrum DX8 Last edited by rossk; 07-07-2012 at 08:12 AM.. |
#13 |
This is my list, shouldn't be hard to figure out pricing with this. I went with everything except the Al. servo supports and Al. 3rd bearing block. Got to warn you though, this setup is massively more expensive than a 450X. It will never bore you though :).
MSH41502 Mini Protos Carbon kit Naked MSH41106 Mini Protos stretch Kit with blades MSH51305 Gorilla Tail Blades Yellow MSH41103 Flybarless hub low MSH41112 CNC Alu pulley set MSH41104 Alu CNC tail pulley MSH41015 Pinion 15T MSH41113 MSH Scorpion Motor 1300KV (6S) MSH41093 ESC MSH by YGE 60 Amp 3x MKS DS95 Micro Coreless Digital Cyclic Servo MKS DS95i Micro Coreless Digital Tail Servo MIK4357 Mini V-Bar Blueline 5.0 Express (upgraded to 5.3 pro) MIK4351 Power supply cable for Mini V-Bar HP-EM2-TACHBL RDU Phase Tachometer for brushless motors Futaba R6203SB 2.4GHz FASST Micro S.Bus HV Receiver Futaba S.Bus Rx Gyro Link Lead P-SBC-LEAD NRG355C-13006 OUTRAGE 5C NRG35 6S1P 22.2V 1300mAH 35C XTREME Futaba T8FG Super 14-Channel S.Bus Radio Tx LiPo's are pretty much gone now and not available anymore. Wanted TP 6S 1300's, couldn't get 'em around here. Ordered some other ones, still have to get 'em.
#14 |
1 other option, since it is your first larger heli, consider a used 1 from the forums. You can save a substantial amount and still have a nice crash kit on the side
You will not be disappointed with it. Start with the 3s set up and turn down your th curve to 70% till you get use to it. Otherwise as everyone else stated, 800- 1100 range to build. kit, motor, esc, 430 3s ( Check MSH-Direct, Bill great guy) servos, (good) 150 (savoxx or similar) Beast x 200 Batts 20-50+ (Turnigy 2200s ,not nanotech) If you want to upgrade: Stretch 70 Low fbl 35? Just shooting these #s off top of my head, pretty close I think???
Keep it in the air! To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Lovin MSH! hybrid Gaz/otos fbl,stretched 6s MiniP Stretched PROTOS 500 ,EC135 Era/Protos500,Compass 6HV, Gaui NX4 all MSH-Brain/Futaba8FG Compass 3D+ CGY750 |
#15 |
#16 |
You guys rock, thanks so much for all the info!
Will probably be end of summer when I start buying/building my Mini... this will give me a great place to start ![]() edit: one more thing... what is "stretched" and why do it? |
#17 |
Stretched is longer boom and longer main blades.
Standard mains are 325mm, stretch is 350mm Gets it flying like a bigger heli
#18 |
If I may suggest, get it from Bill @ msh-direct.com.
BY FAR, the best service in any dealers.
#19 | |
