| Blade 400 Blade Helicopters (eFlite) 400 Helicopters |
Ok I am over having the blade 400 implode itself on spool up. Learned my lesson, no used helis unless I see them fly! Also tear everything down and rebuild.
No one locally wants the parts so either it hits the garbage or I get it in flying shape. I would go flybarless. Zyx gyro. I would keep the original swashplate, it may need new balls, worst case scenario a new swashplate. So I need a new tail rotor shaft, tail boom, probably should get a new belt just to be sure, new main gear, flybarless head (likely tarot). That stuff is easy. The parts I am unsure is the esc and servos. Are there reasonable hobby king servos or what is suggested. how about a good esc with good built in bec? For how much it will fly, backup/spare with no 3d, analog servos for the cyclic will be adequate. Maybe I should upgrade the servos in the blade 450x and use those on the 400? Please let me know your thoughts. This will be on a bit of a budget so no crazy expensive stuff please.
RCHeliCanada.com Field & Support Rep |
Tarot fbl head (non-dfc) $33
Align ball's for stock swash $10 CopterX 3X1000 or Tarot ZYX unit $35/$65 HK 450pro belt tail assembly (comes with belt)$15 Outrage G5 tail pulley (to replace front belt pulley for belt swap) $5 HK ds929mg servos for cyclic $6/each (get a good, fast servo for the tail..dont cheap out there $25-$90??) Skywalker 40amp esc $14 Castle Creations 10amp bec $25 (run a external bec, more current control that way) Turnigy Typhoon motor $13 Build it, fly the poo shizzle out of it and have fun
Tarot / Align 500e DFC (x2) ---Robird G31--- |
I just did a spreadsheet and the cost is at 225 without esc, motor ,servos, bearings, shipping, duty.
Arrgghh maybe just get another 450x or align 450 flybarless. I was unable to find those servos, but there were some others ranging from $4-$8 to the hitec for $20 ish.
I run T-Pro MG90s metal gear servos in my 400. They are super cheap too. I wouldn't put one on the tail though, just the head. I spent about 29 bucks on an Align servo for the tail at the hobby shop and I'm very glad I did. I have a lot better tail hold because of it. I'm running a GY520 gyro and flybar, can't help you on the flybar part.
Here's a link to those servos, hobbypartz also has them. http://www.graysonhobby.com/catalog/...ip6mmj2t5j1s46 |
Yeah, in the long run building a decent upgraded B400 isn't going to be cheap. But consider the new helis. So far I am unimpressed with their servos either. So for me it would double the cost. And they wouldn't fly any better than what I already have! Plus you get the satisfaction of doing it yourself, and improving things as you go. Win Win all the way.
#6 |
Has anyone fitted the flybarless 450x head and swashplate to the 400?
This would maximize similar parts.
#7 | |
Tarot and stock swash will do the deed just fine. You can buy two Tarot heads for the price of the 450X upgrade head/swash..then you have crash parts. I see no benefit in using the stock 450X swash in place of the B400..not really needed.
#8 |
Wish this thread was around last week. I just made an HK order last week, and didn't know about the Typhoon motor as a replacement. Don't want to pay for new shipping.
#9 |
I see good ratings coming from those motors but have never actually had my hands on one. I just wonder if the cans are balanced decently? I have seen hordes of align cans that come out that arent even round! They vibrate the heli in half. Lollz.
#10 |
Yeah..I scored another -6 so, already got one in the 400..now I'll have one in the 450
#11 |
So I ordered the Tarot Head. Can anyone recommend blades for going FBL on the 400?
#12 |
From everything I've read, there's no difference in blades. Stick to some low cost CF and it'll be fine. B
Bee's are not the only ones to fly by beating the air into submission... Protos500 FBL, FrankenBlade400, Blade400 & mCPX's various |
